Old 10-03-2014, 01:51 PM   #1
scotts62
One day...
scotts62's Avatar
Turn signal issues
Ok so I put a '93 crew cab on a '92 frame and used the column, harness and all from the original running and driving 92. It's been a drag out on time working it in between customer jobs and I have everything working but the turn signals. Was intended to be a plug and play but didnt quite go as planned.. I'm going to work on it this weekend to try and figure it out but I can't find a schematic to trace the wires. I think it has something to do with this plug but I can't find the other end. Does anyone know where it might go by chance? Thanks
Scott
93 crew cab build
Project 62
Old 10-04-2014, 05:09 PM   #2
dragginmetal
here, just not logged in
dragginmetal's Avatar
Re: Turn signal issues
Maybe this will help. It's the schematic for exterior lights.
exterior-lights-exterior-lamps-circuit-1-of-1.pdf
dragginmetal is offline   Reply With Quote
Old 10-06-2014, 12:41 PM   #3
scotts62
One day...
scotts62's Avatar
Ill check that out, thanks
Scott
93 crew cab build
Project 62
Old 10-07-2014, 01:33 PM   #4
MaddMech
The plug you're holding is for the rear speakers if they are installed.
MaddMech is offline   Reply With Quote
Old 10-10-2014, 06:20 AM   #5
scotts62
One day...
scotts62's Avatar
Thanks, i ventured out to a pick and pull yard and looked at the wiring while i was out there and figured that i was looking in the wrong are. Figured out that i got a bad relay and it was new so go figure.. Thanks for the pointers fellas.
Scott
93 crew cab build
Project 62
