Old 10-06-2014, 09:54 PM   #1
crazychevyc10
help im stuck! how to remove rear spring top bolt?
hey guys, im in the middle of removing my,rear springs and stuck on how to remove the top bolt holding it in place. i got it loose but it keeps on spinning , how do i get to the otherside of the bolt to hold it in place?
crazychevyc10 is offline   Reply With Quote
Old 10-06-2014, 09:57 PM   #2
Number98
Prestige Worldwide
Number98's Avatar
Re: help im stuck! how to remove rear spring top bolt?
I had one side do that on my Suburban, I finally just cut the bolt. Mine was loosened so I slipped my sawzall in and cut it in half...
Number98 is offline   Reply With Quote
Old 10-06-2014, 10:06 PM   #3
cheyenne shortstep
cheyenne shortstep's Avatar
I guess you are dealing with a coil rear? If so the nut is on top of the lower frame rail under the crossmember that the shocks mount to and is easily accessed with a 3/4 wrench. Give it a squirt with some P.B. Blaster and it should come loose.
cheyenne shortstep is offline   Reply With Quote
Old 10-06-2014, 11:22 PM   #4
crazychevyc10
nevermind..luckily i have long enough arms to read the end bolt haha
