Old 10-07-2014, 08:51 PM   #1
1963chevyc20
1963chevyc20's Avatar
1968 c10 yellow
Hy to all I am looking at purchasing a 1968 c10. I am 17 and will use as a Dailey driver so I need to know avg gas mpg. And will it pull/haul? It has a a 250 I6 and a 3 on the tree. 2 barrel rockchester carb. Very light surface rust. only penetrating rust is the rocker panels. All original she wants 1200 cash.
1963chevyc20 is offline   Reply With Quote
Old 10-07-2014, 08:52 PM   #2
1963chevyc20
Re: 1968 c10 yellow
It is ugly yellow
Old 10-07-2014, 09:22 PM   #3
flashed
Re: 1968 c10 yellow
Sounds like a good price but you will be lucky to get 10 mpg but it will be fun. My 74 stepper has the 250 and 3 on the tree and has plenty of torgue but the mileage aint great.
flashed is offline   Reply With Quote
Old 10-07-2014, 09:45 PM   #4
1963chevyc20
Re: 1968 c10 yellow
Ok. Why so bad? My 63 C20 283 3 on the tre gets 15 mpg.
Old 10-07-2014, 10:22 PM   #5
70shortfleet
70shortfleet's Avatar
Re: 1968 c10 yellow
I love yellow!
70shortfleet is offline   Reply With Quote
Old 10-07-2014, 10:25 PM   #6
68shortwide
68shortwide's Avatar
Re: 1968 c10 yellow
Funnily enough, a bb will get almost the same as the i6s, at first I was gonna build mine as a daily driver but I took a different turn and am now goin with a damn nice truck that I'm not afraid to drive 1k miles in. Ls, od trans, 3.73 posi etc. And buying a 91-96 b body as my daily driver. May wanna think about doin the same.
Jack
1968 swb on air
68shortwide is offline   Reply With Quote
Old 10-07-2014, 10:31 PM   #7
LockDoc
The Older Generation
LockDoc's Avatar
Re: 1968 c10 yellow
The rear gears are usually lower with the inlines. I put an S-10 5 speed overdrive trans in my '67 with the 250 and it works great. It improved the mileage but I don't know how much...
LockDoc
Leon
Old 10-07-2014, 11:37 PM   #8
In The Ten Ring
Re: 1968 c10 yellow
My truck has ugly yellow (mustard) paint but it's had that color since 1972 so I'm not going to change it.
My truck gets terrible gas mileage: 10 mpg? It is a 250 I6 with 3 speed on column and 4.11 gears.
I might eventually change it over to a 3.73 gear ratio.
If you like the truck and you have $1200 dollars, buy it. If I find another panel truck, 1967 to 1970, and I can afford it, I'm buying it.
My ugly paint.
In The Ten Ring is offline   Reply With Quote
Old 10-08-2014, 09:09 AM   #9
1963chevyc20
Re: 1968 c10 yellow
Ok. Will the truck even go 75 mph? How many WTD of oil will the motor need if i darn it at the pan and oil er on up?will a standard wix oil filter work? also the is no breather on the carb. Where can I find one?
Old 10-08-2014, 09:10 AM   #10
1963chevyc20
Re: 1968 c10 yellow
Not WTD I mention qts
Old 10-08-2014, 09:11 AM   #11
1963chevyc20
Re: 1968 c10 yellow
With the truck Bering in so good condition am I getting a good price?
Old 10-08-2014, 09:12 AM   #12
1963chevyc20
Re: 1968 c10 yellow
Damn auto correct!!!
Old 10-08-2014, 09:19 AM   #13
Steve Hafner
Steve Hafner's Avatar
Re: 1968 c10 yellow
Nothing wrong with YELLOW . . . I've been driving YELLOW for 34 years . . . LOL
Steve Hafner is offline   Reply With Quote
Old 10-08-2014, 09:24 AM   #14
1963chevyc20
Re: 1968 c10 yellow
Haha!
Old 10-08-2014, 09:24 AM   #15
1963chevyc20
Re: 1968 c10 yellow
Wish that bus was a 68!
Old 10-08-2014, 09:36 AM   #16
In The Ten Ring
Re: 1968 c10 yellow
I use Valvoline oil and Fram oil filters. I do not know how many quarts of oil mine takes....I've never done any maintenance on it since I parked it once I got it. (Which is why I am working on it, it was parked far too long).
Old 10-08-2014, 10:35 AM   #17
1963chevyc20
Re: 1968 c10 yellow
Ok.
Old 10-08-2014, 12:04 PM   #18
Steve Hafner
Re: 1968 c10 yellow
Not to highjack your thread, but here's a 68 . . . sold many years ago though . . .
Old 10-08-2014, 12:46 PM   #19
Keith Seymore
Keith Seymore's Avatar
Re: 1968 c10 yellow
A 3.73 gear set and an overdrive trans (like the Mopar A833) might pick up the mileage a bit.
Or - a 3.42 without the overdrive.
Are you doing a lot of highway driving, a lot of city driving, or a mix?
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 10-08-2014, 01:03 PM   #20
jsprengeler
jsprengeler's Avatar
Talking Re: 1968 c10 yellow
I like the hood ornament - Mercury/Lincoln??
jsprengeler is offline   Reply With Quote
Old 10-08-2014, 01:36 PM   #21
Pick
Pick's Avatar
Re: 1968 c10 yellow
Yes, it will probably hit 75 even if the engine is tired....mine will barely get there.....but it is about all it has in it to stay going that fast. Mine literally pumps oil out the breather when I do it because it is SO worn out. Mine is a '68, 6 cyl, 3 on the tree, 3.73 rear. I've never checked the fuel mileage.....I go by oil mileage in mine. (yours may not be as worn out as mine is)
A standard oil filter will work. No problem. I'm thinkin' mine takes 5 quarts with the filter.
Check your local auto parts store and you'll be able to find a small chrome air filter that works on the cheap........if you want one more original, that will take some hunting on th classified board or at a local salvage yard.
Keep in mind that it undoubtedly has manual drum brakes on all 4 corners.....stopping won't be as easy as it is new cars.
Bottom line......from what you've described so far, if it runs and drives, I'd buy it.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread"
A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack
Pick is offline   Reply With Quote
Old 10-08-2014, 01:44 PM   #22
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Re: 1968 c10 yellow
My ugly paint.
That's not ugly, what you have is a purty nice color. I also like the the pedestrian site..
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 10-08-2014, 03:00 PM   #23
1963chevyc20
Re: 1968 c10 yellow
I will be doing a mix of driving. 25 mi to work 25 back home. I work 3 days a week. Until summer. I live in the back woods. If I want to go anywhere then it takes 30 min to get to paved road. I know it has sucky brakes.. My 3/4 ton has em to. But I want to leave it all stock. I will NOT put a wrentch to it unless I have to. I will do basic service and tune ups but that is it. Well not true. I will run a true strate Exost with a cherry bomb glass pack and put in new rockers then I am done. I will take a hot battery 1 gallon of gas and some starter fluid and see if I can start it. Has not ben drove or started in a year. This truck means slot to me. It belonged to my best friend until he was hit by a truck and killed last year. He was jogging at 6am and a sundaes didn't have headlights and hit him. I will do a tune up and fill the tires with air and that is all. If I purchase it.
Old 10-08-2014, 03:40 PM   #24
Ochre Ogre
Ochre Ogre's Avatar
Re: 1968 c10 yellow
In The Ten Ring that color isn't ugly and it's not yellow or mustard, that is Ochre. I looked a long time to find one in just that color. I guess it's all a matter of opinion.
Ochre Ogre is offline   Reply With Quote
Old 10-08-2014, 07:35 PM   #25
1963chevyc20
Re: 1968 c10 yellow
I wil take picks Saturday. Get out running and i will post a vidieo.
