10-07-2014, 11:43 PM | #101 |
Re: 73-87 lift spindle installation in the 86 Custom Deluxe
Good idea thanks!
1979 GMC 3/4 ton camper special 454 (7/8in drop) UPDATE: CADDILAC 500 SWAP AND 4X4 SWAP http://67-72chevytrucks.com/vboard/s...d.php?t=518625 1965 gmc 4x4 build : http://67-72chevytrucks.com/vboard/s...d.php?t=724972 |
11-29-2014, 04:09 PM | #102 |
Twistedvegas, where did you get your spindles? I just picked up a '73 C20, 8 lug, and would like a few inches of lift without screwing up the geometry. I haven't been able to find any lift spindles for the 88+ 8 lug, only the 6 lug.
12-10-2016, 05:36 PM | #103 |
Bucannon hey I would like to get in contact with you on what you did here did you notice any ball joint problems after driving it for a Lil while if you can shoot me an email johnbriggs111@yahoo.com
06-06-2017, 05:57 PM | #104 |
These are the spindles I am about to use...
https://www.ebay.com/i/291918856622?chn=ps&dispItem=1 I am also using a set of porterbuilt c20/c30 tubular control arms and 8 lug brakes with heavey duty rotors and calipers.... |
06-06-2017, 06:08 PM | #105 |
Let us know how those arms work. I still haven't worked out a problem with too much camber kicking the top of the wheel out. I've planned on building a spacer for the lower control arm mounts but haven't had any time to work on my truck since I moved.
03-16-2019, 04:33 PM | #106 |
Up!! This is a cool thread dont let it die.
02-11-2022, 08:50 AM | #107 |
Can this thread come back to life?? Have some questions!
Brandon Hoffmann |
Tags |
2wd lift, 73 - 87 lift kit, bucannon, lift spindle |
