Old 10-08-2014, 07:21 PM   #51
Slow Build
Slow Build's Avatar
Re: Just finished cutting my TREX bed wood!
Originally Posted by Irishbleueyes View Post
Im pretty sure if those boards are left wet for an extended period they will absorb the moisture and they will expand. It happened on a deck I built and it buckled bad. Trek say they are waterproof or water resistant? Maybe use a sealer just to be safe..
Originally Posted by jayoldschool View Post
Thanks for the heads up. Hopefully, they've expanded as much as they are going to. Those boards have been sitting outside for a few years, buried in snow in the winter. I think they'll be ok. I bought them from my country hardware store that had old extra stock.
I heard TREX had a few years that they experimented with soft wood shavings that absorbed more water then expanded when it froze. My brother had to replace his deck (mostly paid for by TREX).
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 10-11-2016, 08:46 PM   #52
jayoldschool
Moderator
Two year update...
Bed still looks the exact same. TREX is holding up fine. No expansion, no cracking, no shrinking, no warping. I drilled a couple holes in the front corners for drainage.
jayoldschool is offline   Reply With Quote
Old 10-11-2016, 11:12 PM   #53
Captainfab
60-66 Nut
Thanks for keeping us informed of the long term durability
Old 10-12-2016, 10:17 AM   #54
Holzy
I do a lot of decking and TREX as well as other engineered wood products are quite heavy. Did the weight of this effect your ride/suspension?
Holzy is offline   Reply With Quote
Old 10-12-2016, 11:54 AM   #55
jtrichard
ON a fleet side TREX ONLY adds about 63 pounds to the bed weight (assuming you you 3/4 TREX).... I dont think you would notice the difference.... yellow pine at #39 per cubic foot and Tex at #60 per cubic foot
jtrichard is offline   Reply With Quote
Old 10-13-2016, 09:47 AM   #56
Holzy
I just took my old wood bed out last night, that was fun, and so I have to ask how you were able to get your new flooring under the lip of each box side? And how did you get your cross members stable before you laid down the Trex? As from what I found the cross members are only held up by the floor. To me it looks like the entire floor and cross members must be assembled then brought up from below the bed to meet those box side lips and the rear box support.
Old 10-13-2016, 01:27 PM   #57
jayoldschool
Moderator
I assembled the complete box off the truck. If you're doing it on the truck, raise the bed up on some stands at each corner. Crossmembers in place on the frame. Wood on top of crossmembers, then drop bed on the wood. Drill holes in wood around the perimeter of the bed and wheel tubs, and the holes that go through wood/crossmembers and frame.
Old 09-25-2022, 11:03 PM   #58
Pick121
Pick121's Avatar
In your Finished photo the wood looks black, is it just the angle/lighting or did you change it from the gray weathered look? It looks great
Pick121 is offline   Reply With Quote
Old 09-27-2022, 06:16 PM   #59
jayoldschool
Moderator
Just the light. Bed still looks the same 8 years later. Truck gets used for truck stuff all the time, and sits outside 24/7.
Old 07-24-2023, 08:57 PM   #60
Nevada51
Wow, an eight year review! Appreciate the updates, and that's a big endorsement for TREX, kinda wish I went that route now! A lot of prep and maintenance of normal wood probably should be weighed up in the overall decision of what material to go with. My truck sits outside 24/7 too. If the past is an indicator of the future, I probably won't have my truck in eight years' time to do a review of how my bed wood is holding up!
Nevada51 is offline   Reply With Quote
Old 07-25-2023, 11:54 AM   #61
jayoldschool
Moderator
Still sitting outside, still looks the same. I use it constantly. I'll take a pic later today.
As promised. I sweep it out once or twice a year. I've hosed it out a couple of times.
