Old 10-13-2014, 06:04 PM   #1
backwoodsK20
backwoodsK20's Avatar
Where did you get your lift from?
I'm looking for a 4" lift on a 68 K20, i'll need all 4 leafs and anything else that comes with the kit would be a bonus. Who did you deal with and who did you find had the best deals? I've had a hard time finding 3/4 ton rear springs, lots of places only have 1/2 ton which I don't want.
backwoodsK20 is offline   Reply With Quote
Old 10-13-2014, 08:49 PM   #2
backwoodsK20
Re: Where did you get your lift from?
*reason I need all 4 springs is because the rear springs are both cracked in two, right over the diff.
Old 10-13-2014, 11:13 PM   #3
mjensen
mjensen's Avatar
I ended up getting mine from SDTruckSprings.com. At the time, they had the best deal running for what I was looking for.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 10-14-2014, 02:16 AM   #4
andrewmp6
Talk to http://www.offroaddesign.com/ they don't have it listed but they can get a lot of stuff.
Old 10-17-2014, 02:54 PM   #5
72 Copper C-10
72 Copper C-10's Avatar
Off road Designs all the way! It may be a little more expensive but totally worth it! great products and great people
72 Copper C-10 is offline   Reply With Quote
Old 10-17-2014, 03:04 PM   #6
underliner6
underliner6's Avatar
www.alcanspring.com
Alcan can build you some great leafs. I only here fantastic things about them!
Jim
1972 K20 Cheyenne- 350/350/205
1972 K20 Cheyenne - 350/SM465/205
1971 K5 Blazer
underliner6 is offline   Reply With Quote
Old 10-17-2014, 06:32 PM   #7
72 Copper C-10
Alcan builds ORDs springs, it's a very nice spring. The reason I went to ORD is they have tons of experience our trucks and newer trucks. They actually test their product. I would go through ORD because you either give alcan your specs, you leave the decision to alcan and they can try their best, or you let ORD build a set that is made for your truck, so if you have a big block, or small Block, or any other modifications done the will consider that to build you the best possible spring pack for your truck.
