Old 10-08-2014, 09:20 PM   #51
Modges'66
Modges'66's Avatar
Location: Grand Rapids, Michigan, otherwise known as Beer City U.S.A.
Re: 66 Build
Man, that is a sweet lookin' grill.
I like it a lot!!!
Modges'66 is offline   Reply With Quote
Old 10-09-2014, 12:49 AM   #52
Captainfab
60-66 Nut
Re: 66 Build
X3......
Originally Posted by bomp View Post
custom grill is looking good
Old 10-09-2014, 10:24 PM   #53
Hotrod1952
Re: 66 Build
Thanks for the compliments guys! I actually borrowed that grille idea from a post I saw by Lakeroadster? some time back. Can't remember what site I saw it on either.
Hotrod1952 is offline   Reply With Quote
Old 10-12-2014, 07:09 PM   #54
Hotrod1952
Wink Re: 66 Build
Finally got the inside of the passenger door painted. Got door mounted today. Had a little grief getting it to fit in the jamb nice. But I won.
Old 10-14-2014, 08:17 AM   #55
Hotrod1952
Re: 66 Build
Worked on fitting A/C housing and inner fender together. Had to mod the inner fender and A/C housing (Tire clearance is somewhat tight. I will try get a photo later.) . I started on this last spring and got sidetracked onto other items - now am back to the front end. For those who don't recall. I am installing a A/C from my donor truck a 1987 R20 which was converted to 134A.
Old 10-14-2014, 09:11 AM   #56
Jeff La
Re: 66 Build
Nice work can't wait to see more
Jeff La is offline   Reply With Quote
Old 10-14-2014, 09:20 AM   #57
Turtleman
Turtleman's Avatar
Re: 66 Build
I cant wait to see the AC Fit in... Thats something I seriously need to do.. You do Good work HotRod...
Find a way to download your abilities and I'll plug in.
Turtleman is offline   Reply With Quote
Old 10-14-2014, 07:06 PM   #58
Hotrod1952
Smile Re: 66 Build
Tonight after work I mixed up some tintable bedliner and sprayed the inner fenders inside and out the body color. I think they look sweet!
Old 10-14-2014, 09:00 PM   #59
Modges'66
Modges'66's Avatar
Re: 66 Build
That does look nice!!!
I am kinda wishin' that I would have done that with the underside of my truck!
Mine shines too much for something that I want to drive the crap out of, and I don't know how I will keep it clean!
Seriously, no kidding on this subject.
Old 10-15-2014, 07:38 PM   #60
Hotrod1952
Smile Re: 66 Build
Hauled out A/C system from storage. Started assembly.
Old 10-15-2014, 10:50 PM   #61
Dsuper5
Dsuper5's Avatar
Re: 66 Build
Good Deal Hotrod1952
I have the same set up for my 65 Suburban, not there yet but soon ....
Can you post some pictures from the inside under Dash etc? Would be highly appreciated !
Thanks Eddy
Dsuper5 is offline   Reply With Quote
Old 10-15-2014, 11:04 PM   #62
TJ's Chevy
TJ's Chevy's Avatar
Re: 66 Build
Looks nice! That orange is really gonna stand out!
Old 10-16-2014, 10:22 AM   #63
Hotrod1952
Re: 66 Build
Here's what I have Dsuper5. I will get more up later when I move to the inside of the cab!
Old 10-16-2014, 10:26 AM   #64
Hotrod1952
Re: 66 Build
A few more...
Old 10-16-2014, 10:31 AM   #65
Dsuper5
Dsuper5's Avatar
Re: 66 Build
Nice
Thanks a lot that eased already my headache a bit , good looking dash extension !
Old 10-16-2014, 10:33 PM   #66
Hotrod1952
Arrow Re: 66 Build
These shots show tire clearance to inner fender. I'm using 2.5 drop spindles and expect to install 1" lower springs yet. 3/4 ton truck with 1/2 ton springs in front now. Also need to move steering arm 1 spline over to make this side turn shorter and center the steering.
Old 10-16-2014, 10:49 PM   #67
Hotrod1952
Re: 66 Build
Tonight I did a lot of head scratching. Spent most of the time working out a plan to mount the A/C condensor. With my plan I have to move the battery box 3/4-1" over to clear the refrigerant lines. I used the mounts off the 87 donor truck. One thing I dislike is that I will not get full air flow across the condensor. About 10-15% is blocked. I will be trimming the lower part of the grille support around the condensor as well. I sprayed some semigloss black on the support and called it a day for now.
Old 10-17-2014, 11:29 PM   #68
Hotrod1952
Cool Re: 66 Build
More pics of the front end & A/C install. I slod the battery over about 3/4 inch and up 1". Notched the radiator support for a/c lines to have a clear route.
Old 10-17-2014, 11:34 PM   #69
Hotrod1952
Talking Re: 66 Build
More... I used the condensor mounts off the 87 also.
Old 10-17-2014, 11:38 PM   #70
Hotrod1952
And a wrap up... I had to trim the battery box in 3 places.
Old 10-23-2014, 11:22 PM   #71
Hotrod1952
Re: 66 Build
I've been looking at the a/c condenser for nearly a week and I hate how the mounting turned out. So I went to the big book(Google) and researched what other cars had similar hose ends on the condenser that also was shorter by a good bit. I ended up setting my sights on a condenser from a mid 80's Corvette. I was surprised at how readily available they are used. So the Fed ex truck showed up today with one. I was also happy with how easy it was to bend the lines for hookup. I like the look a whole lot better.
Old 10-26-2014, 07:19 AM   #72
Hotrod1952
Re: 66 Build
I started to fit the grille support. Guess what, I forgot all about the hood latch location when I located my condenser. Ended up cutting the radiator support on the driver side by 1/2 inch. Moving the condenser back as far as I could into the opening. Boy does it fit tight! looks like it will just clear the latch now.
Old 12-05-2014, 09:33 AM   #73
Hotrod1952
Re: 66 Build
Thought I should post up a couple more pics on the progress.
Old 12-05-2014, 09:35 AM   #74
Hotrod1952
Re: 66 Build
Got paint on the top and windshield installed. Started working on the hood. Lots of hail dents on the 40+ year old hood. Found a small spot of rust on the lip, working on repairing. Put bed liner on the underside of hood.
Old 12-05-2014, 09:46 AM   #75
Hotrod1952
Smile Re: 66 Build
Getting ready to start putting doors together. Ordered all the rubber - rivets etc. Should be in today. Found an article on the door locks from Custom Classsic Trucks Apr 2001 edition. I bought a copy off ebay and scanned it to a pdf. I'll try and attach it. I had to compress the PDF files to get them on the forum. I can e-mail them to any who want a higher quality document. Its about 5MB in size.
Last edited by Hotrod1952; 12-05-2014 at 10:03 AM. Reason: no attachment,pdf quality, cannot spell
