Hm, Is it a 1963?
Alright, bought this truck for $200. Believe its an Apache 10, Going to restore it and stuff a 502 under the hood. My question is what year is it? The title says it is a 1963, but i was told they quit making the "Apache" in 1961. So how can i be certain on what year it is? Also can i swap a 1964 style hood to it (like the picture below) New to this era truck so sorry i sound like a rookie. Thanks for any help!
[IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() [IMG] ![]() |
![]() Join Date: Mar 2011
Re: Hm, Is it a 1963?
If it is a 63 someone has already swaped the hood, it should have one like the red one and it would not be an Apache.
63 k20 with cummins 4bt, owned sence 1982 |
If it's a '61 it will have an x frame and torsion bar front suspension; '63 will have a standard ladder frame with coil springs.
Here's the generic info packet from the GM Heritage Center archive for a '63 Chevy pickup. It will show all of the various available options and content.
https://www.gmheritagecenter.com/doc...olet-Truck.pdf Here's the same thing for a '61, just for comparison's sake. https://www.gmheritagecenter.com/doc...olet-Truck.pdf K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
1961 crewcab
I say 61, the interior of a 63 is fawn, that is silver, the column, wheel, and dash cluster on a 63 are white, that is also silver, which shows it to be a 61.
I would inspect the vin tag, which you can see in the pic. 60-63 they are spot welded on from the factory in that spot, is that one screwed on, or riveted? if so it has probably been changed. as mentioned 60-62 have the "X" frame 63 does not. also if still there the data tag on the kick panel (left side) will show which engines are available , 60-62 had 235, and 283 listed, if it was a 63 , it will not show the 235 anymore, but will show the 230, and 292. the hood will fit, but before getting too far along in the build, I would get the title issues straightened out. check out this thread for some more vin info: http://67-72chevytrucks.com/vboard/s...d.php?t=316902 a 63 grille should just bolt right onto that support, you might have to drill a couple of the holes, but the top outer ones do line up. also the 60-62 grille support are different from 63-66, the later ones had a big notch for the frame rail. ...and bumpers for 60-62 are different than 63-66, (they bolt on in different spots) -something to keep in mind when looking for parts.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 Last edited by jonzcustomshop; 10-14-2014 at 01:41 PM. |
Ditto on getting the title verified. That certainly looks to be a '61.
I wouldn't spend any money on it before doing this! |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
The vin tag would start 3C143 first number indicating year.
63 would have rods activating the clutch instead of hydraulic. Shame on the windshield looks like the easy eye tinted option. 63 first year for 12 bolt rear end with pressed on backing plates. We could go on and on.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
Haha, got it all figured out. Long story short, had two trucks, only one title. So i have a vin plate and a matching title, going to have to register it as a 1963. Also re stamp the frame to match. Even though it is indeed a 61. Thanks guys! Another question.. Im putting a Supercharged 502 Big Block in it, will box the frame and some other things, what do i need to do suspension wise, not going to drag it just a fast daily driver. Will stock torsion bars, spinals and all that work and hold the extra weight? (doing a 5 lug, disc brake conversion with 2 1/2 drop spinals) Thanks again!
restamp the frame?
#11 | |
Here.. From a topic posted above
again restamp the frame not a smart move
I would venture to say its against the law. As is changing vin tags. If the year of the truck and vin #'s don't match I wouldn't put a dime into it. It could not work out well for many reasons. The big one being the truck could be stolen. Now you can register a vehicle with the frame vin #'s if the tag is missing. The numbers need to be verified by DMV or the CHP.
That's here in California anyway, I've done it. Good Luck. |
#15 | |
#16 |
Don't know about Colorado. But in California it's very easy. The titled owner just fills out lost title paper work. The best people to ask are those that work for DMV in your state. Changing the vin tag to match the title you have is not what you want to do. Good Luck. Keep us posted.
#17 |
I'm in Colorado, DMV website says all i need is
- Appropriate identification, if your vehicle was purchased on or after 7/1/2006. - The VIN number and title number of your vehicle. - Payment of $8.20 for the duplicate title fee. Where do i find my title number, and also is a bill of sale a good enough proof of ownership since they did not have a title for it as it was lost. |
#18 |
60-66 Nut
Changing the cab VIN tag and altering the frame VIN in definitely against the law and certainly not something you would want to post on the internet that you are going to do.
If this '61 truck is a 1 owner truck and you purchased it from them, then all they have to do is do down to the DMV and file for a lost title. I don't know about Colorado, but here in Idaho, the title transfer can be done at the same time. IMO, installing a big block into a '60-'62 frame is a big PITA. It is much easier in a '63 and up frame. If you get rid of the torsion bar front suspension and go with a later model crossmember with coils and disc brakes, that will help.
#19 |
![]() Join Date: Aug 2004
Your better off having them do a search for the VIN from the 61. Even if it is a lost title, chances are its just that and the owner on the title is not able to be found and the truck isnt stolen.
A bonded title gives you a fresh title in about 3 years, go this route so everything is on the level and legal. My dad had a friend who spent many years and lots of $ on a 57 Chevy Belaire ( i think it was a Belaire) anyway, when he finished it and went to title it, he found out it was stolen 10 years before he bought it. The owner wanted it back and he was out all that time and money. food for though my friend!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#20 | ||
#21 |
![]() Join Date: Aug 2011
Man I love those old bubble hoods. The turn signal inserts and the chevy bow tie are worth about $100 combined.
Good luck on the project. Looks like you picked one that will be a challenge.
http://s994.photobucket.com/albums/af62/ScottAz2/ |
#22 |
Haha, i got it because it was expensive. Looks like its going to take a good amount of work for it to hold a supercharged 502, and a 4l80e trans. I see a lot of one off parts being made for this truck! I could see the hood being a nice item, it just doesn't fit the look im going for. Also got the title situation figured out, previous owner has a new one on the way! Thank Goodness!
#23 |
Six in a row makes it go...
![]() Join Date: Mar 2009
My truck has '66 badges, a '66 VIN, and appears to be a '66. However, it came '65 title when I purchased it from the previous owner. Dunno why, so I just registered it as a '65.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#24 |
Well, Good news today for the build. I got lots of sheet metal for it. Haha paid $100 for all the parts you see in the pics below! Also got all the trash out of it, time to see about shoehorning a big block under the hood haha. Also can anyone tell me what motor is under the hood now? Its mated to an auto trans of some sort... (what a waist would be much cooler as a 3-speed)
#25 |
60-66 Nut
The valve covers are 327 covers, but it could be any small block. The only way to know for sure is to run the casting numbers and or suffix code and see what it is.
