Old 10-15-2014, 02:57 PM   #1
datguy
Old Engine Knocking!
so my old 250 engine started knocking time to get it out!
i need a 292 inline sadly cant find on in my area any body have a lead to where i can score one up for cheap?
datguy is offline   Reply With Quote
Old 10-15-2014, 06:03 PM   #2
LVPhotos
LVPhotos's Avatar
Re: Old Engine Knocking!
How about a in line 6 out of 06 trailblazer at 291hp. The earlier versions were less hp.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 10-15-2014, 06:11 PM   #3
Old Truck Man
Old Truck Man's Avatar
A 292 isn't a direct bolt in replacement. The passenger side frame mount is different. A 292 flywheel has larger crankshaft bolts. Most 292 have a three bolt exhaust flange. You radiator might not properly cool a larger 292 engine. Unless you really need the extra pulling power I would go back with another 250engine.
Old Truck Man is offline   Reply With Quote
Old 10-15-2014, 06:58 PM   #4
datguy
How much do you want for that engine?
Old 10-15-2014, 06:59 PM   #5
datguy
Actually I had been wanting a 292 for a good while now im willing to make the new mods to make the 292 work!
Old 10-15-2014, 11:00 PM   #6
TJ's Chevy
TJ's Chevy's Avatar
Heck yer in California...there's tons of them down there alone. The 292 has a bigger flywheel, clutch, different motor mounts, and bigger radiator.
