Old 10-15-2014, 09:18 PM   #1
Dads79GMC
Dads79GMC's Avatar
Engine Mount Bracket or Whatever It's Called Differences
OK, so I have two sets of these. One set is from my original 1979 LWB frame (dirty ones), and the other set is from a SWB frame (cleaner ones). The cleaner ones are shorter? Why? The longer ones reach the top of the frame, and the cleaner ones line-up under the top lip of the frame. Again, why would these be different, and which ones should I use?
Instagram @HomeBuiltC10s
Dads 79 GMC Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=642929
1978 Silverado Build
http://67-72chevytrucks.com/vboard/s...d.php?t=756016
Dads79GMC is offline   Reply With Quote
Old 10-16-2014, 01:50 AM   #2
jetmech85
Re: Engine Mount Bracket or Whatever It's Called Differences
I wonder if a heavy half frame is just a little beefier than a SWB frame making it necessary for a longer motor mount support? Or if the shorter one is from an '81 or newer maybe the frame is different in that area as part of the weight savings for that body style.
jetmech85 is offline   Reply With Quote
Old 10-16-2014, 08:49 AM   #3
Dads79GMC
Dads79GMC's Avatar
Both the LWB and SWB are Heavy Half frames, I should have mentioned that earlier.
LWB is a 79, the SWB I think is also a 79.
Old 10-16-2014, 09:54 AM   #4
KrazyRay
KrazyRay's Avatar
Did one set come from a big block truck? The big blocks are different.
KrazyRay is offline   Reply With Quote
Old 10-16-2014, 10:04 AM   #5
Dads79GMC
Dads79GMC's Avatar
I can partially answer that question: Fact - the larger set is from the original LWB frame, with the original 350, no big block. As for the smaller set, I don't know.
I think I'll go with the original longer ones rather than the set that came with the donor SWB frame.
Thanks for the input. Mike
