Old 10-14-2014, 10:01 PM   #1
willem445
willem445's Avatar
Installing different mirrors on my K20? Also bed question
I have a 1980 Chevy k20 that I have been working on as a project truck. Ive gotten the engine running pretty good so im starting to address body parts. I just recently bought a 1975 C10 and a 1978 C10 as donor trucks.
Here are the mirrors that were originally on my K20.
The mirrors are in great shape and I would like to use them.
The mirrors on the C10 were the larger 3 point mount mirrors. On one of the doors the mirror is fine but on the other door the mirror is missing.
How would I mount the smaller mirrors that are on my truck currently onto these doors from the C10?
Also this is the bed that I plan to use.
For the most part the bed is in perfect condition except for a few minor rust spots that can be repainted. It is a wood bed as well.
Will this bed mount to my truck fine? Both are long bed trucks. Can anyone reccomend a good replacement wood kit?
Sorry if images are very large.
willem445 is offline   Reply With Quote
Old 10-15-2014, 04:43 PM   #2
johnwaynejeep
Re: Installing different mirrors on my K20? Also bed question
For the mirrors,
It should be simple enough. Just take the inner door panels off your project truck and see how the mirrors mount. It's probably just a couple bolts inside. You'll have to measure and drill new holes to the project doors so you can mount the smaller mirrors to your desired doors. You can have a welder fill in the old holes from the 3 point mirrors and repaint.
For the bed,
I'm not sure if the mounting points are different. I would guess they're all the same for the long beds. Take some measurements from both trucks and make sure everything will line up. Measure from front mount to rear mount of the bed, from the axleshaft to the front mount and axleshaft to the rear mount, from left side mount to right side mount and if all these measurements are the same on both trucks then have at it. Before you remove the bed, crawl under it and look at every inch of the bed to make sure there are no mounts, wires, etc bolted to the bed. You don't want to remove the bed to find out the previous owner drilled the brake light wiring the underside of the bed and end up ripping out the wires.
Robert
1975 C10 - Huckleberry
2007 Jeep JK - John Wayne Jeep
Smittybilt front/rear bumper, 10K winch
Pacific Grove, CA
johnwaynejeep is offline   Reply With Quote
Old 10-15-2014, 04:46 PM   #3
johnwaynejeep
If you want new wood for the bed, there are several parts vendors who specialize in older trucks like, LMC, classic parts of America, Brothers Trucks, they all should have bed kits. If you're wood is in decent shape I've heard of people water sanding the wood to smooth it out again and then resealing the wood. I've never tried this and I would look it up the process online or in a library.
Robert
Pacific Grove, CA
Old 10-15-2014, 05:46 PM   #4
willem445
willem445's Avatar
Thanks for the reply.
Ive been looking around and found some nice OAK wood kits for around $370. The wood in it now is decent enough to use but is very close to being to rotten to use.
Old 10-15-2014, 05:57 PM   #5
walkerb
walkerb's Avatar
Nice trucks. I love the wood floor fleetsides
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 10-15-2014, 06:16 PM   #6
hatzie
Moderator
hatzie's Avatar
Mar-K sells most of the wood fleetside floor parts for the 67-72 fleetsides. They can be used as-is or modified for use on the 73-80 fleetside wood floors.
If you aren't going to use the sport mirrors on the brown doors I'd eBay them.
Dodge used similar Dumbo mirrors with electric remote controls on some of the 1994-1997 fullsize ram trucks. The head could probably be adapted to the GM door mount.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 10-15-2014, 08:06 PM   #7
willem445
willem445's Avatar
I did look at Mar-K. The prices seem to be very high compared to others. The OAK on Mar-k is $512 compared to $375 on classic parts. Would the price difference be that Mar-k drills the holes for you?
I plan on using as many parts that I can off of the C10s and either scraping or selling what is left. Hopefully I can get the $475 back that I payed for them.
Old 10-16-2014, 02:41 AM   #8
dieseldawg142
dieseldawg142's Avatar
one thing to do when changing your mirrors, if the bolts don't go threw the mirror brace inside the door, put a piece of 1"x1/8" flatbar under the mirror bolts to spread the load & save your sheetmetal. my doors went from tri-pod mirrors to the kind you took off & the bolts that went threw just the sheetmetal left nice 1" rips in the metal around the holes
dieseldawg142 is offline   Reply With Quote
Old 10-16-2014, 09:24 AM   #9
willem445
willem445's Avatar
Good idea. Thanks!
Old 10-16-2014, 09:30 AM   #10
hatzie
Moderator
hatzie's Avatar
I haven't had the wood in my hands to compare but there are different grades of hardwood and a couple mm makes a fair difference in price.
The rear crossmember from the 67-72 can be mildly modified to fit the 73-80 beds. Mar-K was the only outfit that had em a few years ago and they were willing to provide stamped but not drilled rear crossmembers and custom height under floor crosspieces as well.
Old 10-17-2014, 07:56 PM   #11
Speeding Dakota
Speeding Dakota's Avatar
I'm working on a '83 project and just finish my doors. I removed the larger style mirrors that you have (the white ones) and covered the holes because I'm planning to put on the drop down peep mirrors.
Anyway, once I removed the mirrors and the internal door panel (from the inside of the door) if you look just below the vent window on the inside of the door skin you will see where the factory made marks to drill out based on the mirrors to be installed. Just drill out the 2 that are closer together if you want to use the smaller chrome sport mirror. You will have to fill in the 3 holes where the larger mirror mounts.
Hope this helps.
Speeding Dakota is offline   Reply With Quote
Old 10-18-2014, 04:07 PM   #12
willem445
willem445's Avatar
Hope this helps.
Should help a bunch!
