Old 10-16-2014, 04:55 PM   #101
CaliforniaDaddy
CaliforniaDaddy's Avatar
Re: My 1950 Chevy "S-3100" Build (old+new)
Originally Posted by tlorber View Post
Great find, and thanks for the pic on the steering column.
welcome
“I would rather live my life as if there is a GOD and die to find out there isn't, than live my life as if there isn't and die to find out there is.”
CaliforniaDaddy is offline   Reply With Quote
Old 10-29-2014, 11:15 AM   #102
CaliforniaDaddy
Had some time yesterday to mount the gas/brake/clutch & e-brake pedals from the 97 S-10 to my 50 CAB. Not sure if what I did was the right way but looks like it works for me. I had to install my seat and check the feel of the pedal locations and feels good. I'm even going to adapt the S-10 E-brake pedal as well.
Old 10-31-2014, 02:01 AM   #103
tlorber
tlorber's Avatar
Cal Daddy, that is some great progress.
I'm not sure if you did the final burn in on the cab mounts, but I've noticed that as the weight increases on the front end (as the springs sink lower) the upper control arms change position fore and aft relative to the wheel well.
Have you set your your steering linkage yet? I'm trying to figure out a path around my headers.
tlorber is offline   Reply With Quote
Old 10-31-2014, 09:26 AM   #104
CaliforniaDaddy
No I haven't finish the mounts yet. they are only tacked in place. I haven't set my linkage yet.
Old 11-08-2014, 08:45 PM   #105
CaliforniaDaddy
Well today I wanted to test fit the SBC350 and the NV3500 5-speed in the chassis. Im a little confused as to where to line it up. If I push the engine all the way back for 1" clearance between the Distributor and the firewall, the motor mounts are no where near the perch-mounts. Should I have this much clearance from the firewall??? I'm confused.
Old 11-08-2014, 08:47 PM   #106
CaliforniaDaddy
Here are a few more.
Old 11-08-2014, 08:48 PM   #107
CaliforniaDaddy
and a few more.
Old 11-10-2014, 06:49 PM   #108
tlorber
tlorber's Avatar
My LM7 sits about 4" back from where the original 4.3L V6 did on the S10. I bought some mounts allowed them to bolt into the original mount holes (you can see on my thread). However, due to your distributor you may not be able to get the SBC to fit in that exact spot without dinging in the firewall.
Old 11-10-2014, 08:26 PM   #109
CaliforniaDaddy
So why would I need to go so far back? I hung all the sheet metal today and checked the distance between the water pump nose cone and the electric fan. I have about and 1"+ Is that all that is needed?
Old 11-10-2014, 08:33 PM   #110
tlorber
tlorber's Avatar
As long as your fan clears you should be ok. Just make sure you can get all your wires on the distributor, and that you have a little room for the motor to vibrate or load up under torque without hitting the firewall. The main reasons people want them back are 1) to clear the fan and 2) to shift as much weight to the rear as possible, since the trucks tend to be front heavy-unless there is a lot of cargo in the bed.
Old 11-10-2014, 09:15 PM   #111
CaliforniaDaddy
Okay cool, Gotcha! Too bad you weren't closer. I would love to have a helping hand and another brain for re reinsurance!!
Old 11-11-2014, 01:24 AM   #112
CaliforniaDaddy
Im wondering why the truck still looks high in the front, even with the 2" drop spindles and 20" rims. Is it just me??
Old 11-11-2014, 02:48 PM   #113
tlorber
tlorber's Avatar
Looking at Robert's description on the AD Engineering site, you still have a bit of weight to add-seat, grill, fluids bumper, doors, etc, maybe 2-300 lbs? I could not tell if you have the bed on, but even though most of its weight will be borne by the rear, it will lower the front as well. When I jump on the rear of my frame, the front fenders do come closer to the ground slightly. Now, does that all get you as low as you want? That is hard to say. I guess you'd have to estimate the weight and place it on the truck (maybe sacks of cement, or whatever dead weight you have sitting around).
Old 11-11-2014, 08:17 PM   #114
CaliforniaDaddy
Well I hope so. I would hate to get everything in and have to take it apart to get the sheet metal lower.
Old 11-11-2014, 08:32 PM   #115
CaliforniaDaddy
here are some more pictures pulled out of the garage. See the front wheel gap. Im wondering If I need to lower the front of the cab?
Old 11-13-2014, 05:58 PM   #116
IWanna49
IWanna49's Avatar
Looks like the fenders are sitting high, especially with the drop spindles on and the engine in. Have I told you lately that I love those wheels???
Is that cab for sale???
-Greg
'51 3600/s10 swap- in progress
Build thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=641511
IWanna49 is offline   Reply With Quote
Old 11-13-2014, 08:59 PM   #117
CaliforniaDaddy
Today another fellow member Brad AKA"kustombrad" came over and gave me some great Ideas to help address the (Pre-Runner) look im having. Thanks again Brad! Seeing his truck in person was kinda like seeing a celeb lol. Plan is to pull out the front springs and set the front up at ride height and then I plan to adjust the front cab mount pads until the desired height is achieved.
Old 11-17-2014, 08:35 PM   #118
CaliforniaDaddy
Well today I pulled out the stock S10 front body mount pads, and boy did it drop the front end way down. Almost too low, considering I still need to pull out the front springs and set it up at ride height. But I'm going in the right direction.
Old 11-18-2014, 07:24 PM   #119
tattooedblue
Looking good with the front lowered!
tattooedblue is offline   Reply With Quote
Old 11-18-2014, 08:58 PM   #120
CaliforniaDaddy
Thank you. today I pulled out the front springs and set up the front @ near ride height. Then I took a few more pictures.
Old 11-18-2014, 09:55 PM   #121
IWanna49
IWanna49's Avatar
Now we're talking!!!! Lookin good!!
-Greg
Build thread:
Old 11-18-2014, 10:10 PM   #122
CaliforniaDaddy
Thanks Man, Looks like I need to move the bed forward about 3/4" as well
Old 11-19-2014, 08:42 AM   #123
tattooedblue
That is the perfect stance for your truck right there.
Old 01-12-2015, 02:13 PM   #124
CaliforniaDaddy
I'm still alive, Just with holidays, new years and wife's birthday. Im trying to play catch up on a few customer cars, so I can start back on the 50 again.
Old 01-12-2015, 02:24 PM   #125
tlorber
tlorber's Avatar
Nice to hear you're kicking-and still have motivation for the truck.
You always have to wonder when you see a long absence.
