Old 10-17-2014, 05:11 AM   #1
gearhead2069
Aluminium Radiator...
Hello all. Getting ready to pick up a radiator for my 51 3100. I am trying to plan ahead in order to keep this ball rolling and will soon be looking into getting my engine/tranny squared away. I want to go ahead and pick up my radiator just to ensure that I have good clearance once I start placing the motor mounts. My plan is to run with an LS3/6l80/90. I'd like it to be aluminium and built to last. I am looking to hold nothing back with this build (within reason) as it will be my daily once it is finished and if I'm going to spend money, I want the money that I spend to last. Has anyone had experience with the 3 core aluminium radiators that Brothers offers? Do they work well with the stock shroud and without much modification as described? Quality construction?
Here is a link to the product in question.
http://www.brotherstrucks.com/prodin...number=ALR54C3
gearhead2069 is offline   Reply With Quote
Old 10-17-2014, 07:45 AM   #2
Advanced Design
Advanced Design's Avatar
Re: Aluminium Radiator...
I haven't had experience with the radiator from Brothers. We used a PRC radiator on the 48 truck and plan to use one for the 48 Suburban build. PRC will add the steam vent and relocate the upper neck for the LS. They have a shroud and SPAL fan option available too making that part of the build a little easier.
http://www.prchotrod.com/products/ch...-radiators.php
Only thing I didn't like was the need to drill the mounting tabs for bolting the radiator in.
Advanced Design is offline   Reply With Quote
Old 10-17-2014, 10:03 AM   #3
NEWFISHER
NEWFISHER's Avatar
I used a Champion. It dropped right in and dropped the temp.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-17-2014, 09:29 PM   #4
gearhead2069
Thank you all for the recommendations.
Old 11-06-2014, 10:52 AM   #5
SparkyRnD
SparkyRnD's Avatar
we make a bolt-in radiator for your truck here in the USA. We are also a forum sponsor and offer a discount to members.
http://67-72chevytrucks.com/vboard/s...d.php?t=628628
www.RnDFabrication.com
Custom Radiators, Valve Covers and Overflow Tanks
SparkyRnD is offline   Reply With Quote
Old 11-06-2014, 01:52 PM   #6
gearhead2069
Thank you for the reply! You probably just made my business! I went through your site and I didn't see how many rows your radiators have; can you educate me?
Old 11-06-2014, 02:01 PM   #7
SparkyRnD
SparkyRnD's Avatar
All of our radiators use dual 1" thick cores, for a total core thickness of 2" (same as a brass & copper 4-core thickness). That style radiator has around 44 coolant tubes per core (approx 88 total coolant tubes on that model)
Old 11-06-2014, 02:16 PM   #8
gearhead2069
Awesome! Thanks guys!
Old 11-06-2014, 04:37 PM   #9
1-ton of fun
polishing a turd
1-ton of fun's Avatar
do you have a cross flow option for a 59 chevy truck? i have a stock style aluminum one, but it hits my ps box, so i need the crossflow to add some clearance at the bottom.
59 chevy apache 31 4x4 - my project: http://67-72chevytrucks.com/vboard/s....php?p=8668512
53 buick special - straight 8 sled - blow through turbo
47 gmc - flatbed hot rod build
99 ford econoline e350 - 4x4 converted family roadtrip/overlanding rig AKA 'Monstervan' AKA 'Daddy-Van'
1-ton of fun is offline   Reply With Quote
Old 11-13-2014, 12:45 PM   #10
SparkyRnD
SparkyRnD's Avatar
We don't currently have them for 1955-1962 models, but if someone wants to send us an original and be willing to test fit with pictures, we can easily make them and would also give an additional discount (PM me if interested)
Old 11-13-2014, 03:39 PM   #11
Iceburgh
Iceburgh's Avatar
This is who I used with my LS conversion. you can check my link for the build.
If possible set you motor back 3" you will make life easier in the long run.
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 11-13-2014, 04:33 PM   #12
NEWFISHER
NEWFISHER's Avatar
And use cardboard to protect the fins during mock up. Only remove it when you are ready to start the truck. You can walk into the garage and the fins will bend. This has been my experience with every radiator I try to keep looking good.
GOD BLESS AMERICA!
Old 11-13-2014, 04:54 PM   #13
SparkyRnD
SparkyRnD's Avatar
good suggestion. A lot of it has to do with the thickness and type of aluminum used for the fins too. Ours can take basic handling and not bend, but more aggressive use can make them deform. the good part is with a very inexpensive fin comb, you can easily straighten them out on most radiators.
Old 11-13-2014, 05:58 PM   #14
4DSEVEN
4DSEVEN's Avatar
Originally Posted by newfisher View Post
i used a champion. It dropped right in and dropped the temp.
x2
4DSEVEN is offline   Reply With Quote
