Old 10-17-2014, 09:39 AM   #1
drumsdaddy
1988 GMC 1500 Brakes
New guy to the forum.
I have pre-owned '88 GMC 1500 and I have a brake problem. It started out as a "brake light" that stayed on. Further investigation of the system and I found that the entire brake system needed replacement. I replaced the following:
New rear shoes, new cylinders, new brake hardware, turned rotors and drums, new brake hoses, replaced (2) rebuilt master cylinders, replaced a single diaphragm vacuum booster with a dual diaphragm booster (rebuilt), replaced the molded vacuum booster hose. I did not replace the front calipers. I checked them and they are working correctly. My results of all this work leaves me with a hard brake pedal that won't stop this sled. Before all of this work I had a soft pedal that wouldn't stop this sled. The only thing left besides the front calipers is the proportioning valve. I have one ordered so I'm hoping this is the problem. No, the "pin" did not extend out to be pushed back in to bleed the brakes as it explains in the shop manual. I took the old valve apart and found that the valve inside the body was stuck. It took some muscle to remove the valve. Shouldn't have to "muscle" a valve as small as that! I did notice when I was bleeding the system that there was a small amount of leakage at the ends of the valve.
Yes, I have a power bleeder and bled the lines numerous times.
I did remove the RWAL part of this system and tied the lines to the proportioning valve in the correct way. I am not a fan of electronic brakes on any vehicle.
So that's about the size of it. Any and all help would be much appreciated!
Thanks!
Drumsdaddy
drumsdaddy is offline   Reply With Quote
Old 10-18-2014, 09:17 AM   #2
poncho62
poncho62's Avatar
Re: 1988 GMC 1500 Brakes
Obviously, when you did all this work, you bled the brakes...I figure that solved the soft pedal problem
I would go ahead and replace the front calipers, for all they cost....What type of pads are you using on the front?
These trucks are known for crappy brakes...I put NAPA Adaptive One pads on my 97, helped a ton
http://www.napabrakes.com/magnoliaPu...ptive-one.html
Ontario Rodders
poncho62 is offline   Reply With Quote
Old 10-20-2014, 07:54 AM   #3
drumsdaddy
I might as well replace the calipers. The brake pads are Best Brakes. I went middle of the road since the truck usually gets driven weekends or when needed. I'm installing a new proportioning valve tonight and go from there. Yep, bled the brakes more times than I want to admit.
Thanks Poncho62 for the advice. I'll let you know what happens!
Drumsdaddy
Old 10-22-2014, 07:58 AM   #4
drumsdaddy
Update on the brake issue. Replaced the front calipers and a new proportioning valve. EUREKA! The brakes are back!
Thanks again poncho62!
