#26 |
Re: VDO Gauge Panel Build - Using factory housing - 86 C20 Suburban
Cool gauge swap! I'm picking up my NV4500 in a couple of days so this setup may go into my truck since I will be needing a speedo
88' Chevy V30 3+3 4x4 Dually 454 TBI/NV4500/NP205 |
#27 |
That is such a great write up! Step buy step, thank you for taking the time to do it!
Faith and Patience with my truck, that is what i pray for every day! See my build http://67-72chevytrucks.com/vboard/s...d.php?t=580013 |
#28 |
Moderator
![]() Join Date: Oct 2008
If it's the 4x4 the speedo gears are in the xfer case. I kept using the same ones I had in my NP208.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
#29 |
A dodge transmission also has mechanical speedo gears in the tailshaft for a 2WD housing. I just happened to find a GM transmission really cheap, and I never really cared for the factory gauges anyways, so this was a win-win situation for me.
86 Chevrolet K20/30 Suburban - 8.1/NV4500/NP205/Dana 60/14 bolt FF, build in progress 73 Formula - 400/Doug Nash 4+1, resto on hold 86 Chevrolet K30 3+3 - 350/TH400/NP241, Air Force/Forest Service Rescue Truck, for sale 01 Ram 2500 - 5.9L Magnum, daily driver 91 BMW 325i - Chumpcar series racecar |
#30 |
I was going to be doing an NV4500 swap into my CC when I get the time. I was also putting in the front buckets & console into my CC from a Suburban. Would you mind posting a picture or a measurement of the distance between the shifter boot and the console. Doesn't appear to be much room and I need a T-case shifter also. Thanks
#31 |
I can get you that tomorrow, I plan on taking it out for its weekly drive tomorrow anyways. There's more room than you'd think, but I'll get an exact measurement.
#32 |
Are there any gauges that fit the small holes like the 4" fit the large? I will be doing this on my '77 but would like to do as little cutting as possible. Btw, it came out amazing and the write up is awesome. Oh, and did you use factory sending units or VDO?
Posted via Mobile Device |
#33 |
great write up and something i would like to do. any chance of getting the pictures back up or a link to them?
1981 Silverado C10 LS/4l60e My truck may be loud and ugly but I love her like bacon |
#34 |
#35 | |
Updated post with reloaded pictures. The original post was too old to edit, so I'm doing them with a quote. If a moderator wanted to paste this quote back into the original post, this post can be deleted.
#36 |
![]() Join Date: Jul 2014
Any ideas why the images don't show on my end? I even clicked on the broken-image icon and it goes to Imageshack and asks me to start an account.
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
#37 |
I was unable to edit the first post. The new pictures are reloaded in a quote in post #35.
#38 |
Sniper - if I understand correctly from reading the text, you were able to use your '86 bezel over an earlier '70's square body housing after all the surgery was done to fit the gauges?
I installed the low profile Speedhut spin on gauges in my '74 C20 build. Due to time constraints and an aborted hydro-dipped bezel install on a bezel that was not the correct year, forced, forced me cut up my really nice OEM bezel. I am not 100% satisfied and want the gauges more recessed than the front mount option we were left with. . . the visibility is not optimal as they are currently. I have been considering fabricating a custom bezel to recess the gauges, but it sounds like you used your flat one-piece '86 bezel on the mid '70's dash housing and bolted the unmolested bezel back on. . . correct?
#39 |
I'm getting a bit confused with the terminology, but I'll try and explain what I used and what I modified.
The only donor part I used that wasn't from my '86 was the metal instrument cluster face from a 70s truck. This is the black piece of the instrument cluster itself that surrounds the gauge faces in their housings, and bolts directly to the light blue instrument cluster housing. This piece was plastic in my 86, and I didn't feel like it would be sturdy enough to hold the weight of the gauges being attached directly to it. Everything else was from the 86. I had to cut up the instrument cluster housing (the light blue piece), and the clear lens of the instrument cluster. I didn't have to modify the bezel at all (the aluminum colored and black plastic trim piece that surrounds the gauges and includes the AC vents, radio, etc), it clears the gauges faces just fine since they are still in the factory location and depth. Hope that helps!
#40 |
Perfect!
Thanks!
#41 |
I know the pieces fit
I borrowed your ideas for my 85 when I removed the idiot lights for real gauges. I kept the stock speedo and fuel gauge though. Real happy with it.
#42 |
Glad to know that it's helping people out. I'm still very happy with the gauges several years later, and I'm finally getting around to finishing the interior repaint, sound deadening, and carpet that I started back in 2012. Right now the car is apart for a Vintage Air install while I take care of those other things. After that, the windows are coming out to deal with some leaks and rust that's starting to form, and it will likely get a repaint to go along with. There's also an 8.1L along the way to replace the old 454 between the fenderwells. I'll try to do some more writeups as I go along.
#43 |
Do you follow Dirty Larry? He's the resident expert on 8.1's and square bodies. Probably THE expert.
#44 |
Absolutely. I think I've read every post that he's made on the 8.1, and there's a ton of good info he's added to the community. I actually used a lot of his information when I did the NV4500 swap on the truck, so it's only natural to follow along with the 8.1.
