Old 10-18-2014, 02:14 AM   #76
wreckedchevy
wreckedchevy's Avatar
Re: My Daughter's 72 just made it home
here's another update. Got it up on a lift finally she is really rusty by MT standards. also found the wheel bearings, pitman arm and rag joint are shot. we replaced the wheel bearings today and now that my daughter has learner permit I ran it over to a nearby gravel road and she finally got to drive it a little bit and definitely confirmed the need for power steering she did fine going threw the curves but when we had to do a u turn in that narrow road it was a work out. I have rounded up 73 and up pump and steering box but I still need year correct pump mount so she doesn't have to replace water pump, alt brackets and all the pulleys. here's some pic's of the old girls rusty bottom.
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
Old 10-18-2014, 09:47 AM   #77
adricar1
Hi Craig its not too bad better than mine.. Bondo Bob is the truck i am on at the moment, PO said everything had been done? what he meant to say was with bondo. both inner rockers where shot, outers replaced and glued on( will not pass an inspection here) and all four outriggers have been changed. My Cab corners were also shot , and part of the inner floor. Take plenty of reference points and keep the outer outriggers on as long as possible because it will act as a reference point for the inner rockers,they also at the front hold the bottoms of the wings on, and even with the repair hard to get lined up correctly. best of luck,and stick with it.
GMC K1500 1971 350 cu in th350 4wd
Bondo Bob c 10 1971 stepside th 350
c10 1970 350 cu in manual air con stepside.
adricar1 is offline   Reply With Quote
Old 10-18-2014, 12:26 PM   #78
wreckedchevy
that sucks when people don't repair things correctly tends to make a bigger problem for the next guy in which case I guess I'm lucky that this is a very honest truck no hidden surprises.
we also figured out the rest of the painted over door logo it's Central Electric wish they wouldn't have painted it over.
Old 10-18-2014, 02:00 PM   #79
Xeen
Xeen's Avatar
You may want to look at the LMC catalog page 25 and figure out if it would be cheaper to replace the entire floor or to patch the rust.
Please call me Brian.
Check out My 1972 SWB Fleetside 5.3L Vortec Restomod Build
Xeen is offline   Reply With Quote
Old 10-18-2014, 02:07 PM   #80
wreckedchevy
thankfully there's a guy in town that stocks all the patch panels so no freight as soon as I find employment again he's going to teach me how to do my rocker's, cab corners and then hopefully i'll be able to do her's
Old 10-18-2014, 07:46 PM   #81
Dean'smeanmachine
Dean'smeanmachine's Avatar
not as bad as mine was!!
Dean
1972 Custom Camper c/20 5.3 LS swap in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=610187
in God we Trust
Dean'smeanmachine is offline   Reply With Quote
Old 10-18-2014, 07:48 PM   #82
Dean'smeanmachine
ive got lots of pictures on those repairs if you need reference
Dean
in God we Trust
Old 10-25-2014, 06:22 PM   #83
wreckedchevy
FORDBGONE!!!! finally got all the extra holes welded up in the doors, removed those lovely ford mirrors, a little rattle can primer and paint and got some repop 72 sport mirrors installed. hoping I can buff it a bit around the edges of the new paint and hopefully get it to blend a little better but otherwise good to go until she get's rich and can afford the rust repairs. so far she's into the truck about 850-900. Thankfully the local's have been being pretty nice to her.
Old 10-25-2014, 06:52 PM   #84
wreckedchevy
this is what the other's were up to while we were installing the mirrors
Old 06-24-2015, 12:16 AM   #85
wreckedchevy
here's a little update now that warmer weather is here finally started tinkering with the smurf a little bit. finished up the 7 pod inst swap, installed a new dash pad and seat cover. hauled a little over a ton of gravel home with it those weather checked tires had me nervous as hell and that bad engine smoke got a whole lot worse under load hee hee. feel sorry for all those that got stuck behind me. looking for a good turbo 350 and we are going to swap out the motor and trans and she should be pretty much ready for the road at least.
Old 06-24-2015, 01:47 AM   #86
In The Ten Ring
THAT'S IMPOSSIBLE!
How can a 1/2 ton truck haul more than a ton of anything?
That's great man! One of the first things I want to haul in mine is a load of gravel and a load of "attic dek" to floor my house attic.
I really wish you could save the 307 but it will be much cheaper to just get a good 350.
In The Ten Ring is offline   Reply With Quote
Old 06-24-2015, 08:03 PM   #87
wreckedchevy
Originally Posted by In The Ten Ring View Post
THAT'S IMPOSSIBLE!
cheaper cause the good 350 is a freebie. probably eventually rebuild the 307 and put it back it would be good for her to see how to build a motor
Old 08-21-2015, 10:42 PM   #88
wreckedchevy
tomorrow we start the heart transplant, finally!
Old 08-22-2015, 02:05 PM   #89
wreckedchevy
If one of you is really bored it wouldn't hurt my feelings if you told what year this motor is. Suppose to be 4bolt 350 and it was free
Old 08-22-2015, 02:48 PM   #90
68350
68350's Avatar
The 010 blocks are good blocks. Should be a 327 or 350. Do you know what the suffix code is on the pad in front of the passenger head? That'll pinpoint what the motor came out of originally. Keep up the good work
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 08-22-2015, 03:58 PM   #91
wreckedchevy
No dice looks like they painted over the numbers really thick. Pulling the heads now I'll see if they surface when we start scrubbing
Old 08-22-2015, 04:01 PM   #92
wreckedchevy
Old 08-22-2015, 04:02 PM   #93
wreckedchevy
Old 08-23-2015, 04:42 AM   #94
Xeen
Xeen's Avatar
How do the heads look, any bent valves or push rods with rocker arms sitting at odd angles, or does everything look good?
Old 08-23-2015, 07:17 AM   #95
bill3rail
bill3rail's Avatar
Nice truck! Lucky kid to have a dad like you!
bill3rail is offline   Reply With Quote
Old 08-23-2015, 11:25 AM   #96
wreckedchevy
everything looked pretty good in the heads, very little lip in the cylinders. little concerned about the right side for some reason somebody coated every head bolt in red silicon from top to bottom. no idea why somebody would do that or if there was a problem with that side that they thought that would actually fix. the guy that owned it is a local engine builder but he never opened it up he bought a jeep for his kid and it had this motor in it said it ran great but was puffing a little smoke on cold start so he built his kid a 383. he's got nothing to gain since he gave this motor away to me but hopefully all is still well.
thanks, it's been a lot of fun hopefully it all works out in the end
Old 08-23-2015, 11:36 AM   #97
wreckedchevy
forgot to add, I still can't find any numbers on that front pad. they really laid down some thick black paint I was hitting it with brake clean and a wire brush and it's not budging. had some troubles getting a oil pan gasket as well all the 80's 350s showed the same gasket thankfully one of the o'reilly guys remembered having to get one from a 307 and he was right. which had me confused still as well since I thought all the small blocks would have the same pan gasket
Old 08-23-2015, 12:24 PM   #98
gordyzx9r
Junior Member
gordyzx9r's Avatar
That's awesome. I had a '72 in high school too...I went to Shepherd (cow pie high), Go Mustangs! Worked at the Kmart in the heights. My dad used to be a regular at the Jailhouse. I heard that's all gone now...I haven't been back to MT in almost 20 years now.
gordyzx9r is offline   Reply With Quote
Old 08-23-2015, 02:13 PM   #99
wreckedchevy
Goofiest looking starter I've ever seen ha-ha
Old 08-23-2015, 03:52 PM   #100
FIREBALL
(007) aka Houdini
FIREBALL's Avatar
Lol, nice pic thats kinda of a .....I'm up to no good kinda smile there 😆
Live life one day at a time!
FIREBALL is offline   Reply With Quote
