Old 10-17-2014, 04:20 PM   #1
Figuarus
Figuarus's Avatar
Quadrajet Conundrum
Guys,
I have a Quadrajet on my 283. This 283 has 1.92 Fuelie heads.
I have a stock cam.
I need to rejet this thing since it came from Los Angeles, and It's running WAY too rich.
The problem I'm running into is two-fold. First, While I CAN rebuild a carb, I know next to nothing about the Q jet. Second, I'm having trouble finding information on what size jet to use for my elevation.
I'm now at about 4500 feel elevation.
Has anyone done this before, or know of a chart to find the right size jets?
thanks again guys!
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 10-17-2014, 04:27 PM   #2
geezer#99
geezer#99's Avatar
Re: Quadrajet Conundrum
Running too rich is what you want at your elevation,
You need to fix that before you consider re-jetting.
First you need to put as much initial timing into your motor as you can and still have it start good when hot.
Then turn your idle down and get your carb back on the idle circuit. Likely it's idling on the power circuit.
What's your initial timing set at?
Old 10-17-2014, 05:17 PM   #3
68Gold/white
www.cliffshighperformance.com
You will need the carb number. You need to send him an email first. Cliff stays about one year behind on carbs builds. Phone calls slow him down. He COULD talk on the phone all day...He WILL help you, if you let him...
68Gold/white is offline   Reply With Quote
Old 10-17-2014, 06:00 PM   #4
jayoldschool
Moderator
A quad is a BIG carb for a 283. If it were me, I'd move the quad along, and go with a nice fresh Edelbrock or Holley 500. I prefer the Edelbrock, but I'm crazy like that.
jayoldschool is offline   Reply With Quote
Old 10-17-2014, 07:08 PM   #5
66Submarine
66Submarine's Avatar
The secondary circuit is big, but the throttle bores of the primary circuit are actually slightly smaller than the OE 2 barrel setup.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-17-2014, 07:19 PM   #6
HumphreyMurdoch
HumphreyMurdoch's Avatar
I don't know diddly squat about Quadrajets. But, if you run an Edelbrock carb, get a 1/2" phenolic carb spacer to help with hot soak starts.
'62 C10 LWB fleet side.
283 w/ a T5
HumphreyMurdoch is offline   Reply With Quote
Old 10-18-2014, 12:33 AM   #7
cortcomp
cortcomp's Avatar
Some q-jets have an APT setting letting you adjust mixture with a screw on top (primary side.) You likely don't need smaller jets as much as larger rods.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 10-18-2014, 01:37 AM   #8
geezer#99
geezer#99's Avatar
All quadrajets have an apt. Two different styles. One in the baseplate or one by the airhorn.
Old 10-18-2014, 08:43 AM   #9
bonehead
bonehead's Avatar
the rich running could be leaking well plugs, google it. This is a common issue with Q-jets, I redo the well plugs on all my q-jet rebuilds.
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
bonehead is offline   Reply With Quote
Old 10-18-2014, 11:29 AM   #10
Figuarus
Figuarus's Avatar
66Submarine, you are correct, the primaries are smaller than the 2gv this thing used to have.
geezer#99, Im not sure where my timing is at the moment, but I will find out in the next day or so. I need to go get a timing light.
I DO need to rebuild it since it's pretty evident.
So, just so i'm clear, The carb running too rich at this altitude is NOT a problem? I was always under the impression that I needed to lean it out for altitude since it's been tuned for Sea-level operation.
I was under the impression that changing the timing will affect power, but not necessarily mixture.
I also did some reading on the carb number, turns out this was made in 1982, and was made for Automatic trans applications.
2013 Malibu LTZ
Old 10-18-2014, 11:41 AM   #11
geezer#99
geezer#99's Avatar
You need to up your jet size 1 number per 2000 feet elevation. That's richer.
Timing affects your mixture because with max initial timing you can get your carb idling on the idle circuit. The timing speeds up your motor allowing you to close the throttle to get back to the idle circuit.
A quick check to see if you're idling on the power circuit is to adjust your mixture screws. If you can close one or both off all the way then you're idling on the power circuit.
When you get your timing bumped up and your idle turned down, you might find the richness goes away.
That's why the rule has always been "Timing first, carb second'.
Old 10-18-2014, 11:47 AM   #12
awbrown
While I build a pile of Q-jets and have great success with them , I don't know a whole lot about jetting , except I used to change the jetting in the truck I drove to school ,a 180 mile trip on weekends .. The jetting that gave the best power was also the jetting that gave the best gas mileage .. in my truck it was 74 in the primaries.. Q-jets have more than one problem that can make them run rich , bad float , improperly set floats , leaking welch plugs under the primary wells ,and a few others I wont get into .. My advise is to get a another carb from a small cubic inch engine that you know runs well , other than that get a junk one and start getting good at assembling it ,they sure are not a holley or carter .....
awbrown is offline   Reply With Quote
Old 10-18-2014, 11:51 AM   #13
awbrown
Also as altitude increases the air gets thinner meaning you need less jet ,as air gets denser such as a cold day or lower altitudes you need more jet .. here is a guide ..
ALTITUDE
As you increase your altitude the octane requirement decreases 1-2 octane per 3000 feet elevation. This is because the density of the air is reduced or there is less air available for your motor to burn. The higher the altitude, the richer your motor will run, making it necessary to re-jet the motor in order to lean it out. The fuel volume remains the same and the air volume goes down. If you have a vacuum advance, as the altitude increases, the motor makes less vacuum and the air fuel ratio becomes richer due to the decreasing air to fuel volume.
TEMPERATURE
When the temperature goes up, the air density decreases, thus you have less air available for combustion and your air fuel ratio becomes richer. The same works in reverse. As the temperature goes down, you end up with more air per cubic foot, and without re-jetting your carburetor, the engine will run leaner.
AIR DENSITY
As the air density increases, your engine will lean out. As the air density goes down, the engine runs richer. Like driving up a mountain, at the top, the motor has less power because you have less air to burn.
HUMIDITY
When the humidity increases, octane requirements ease. The formula is something like... for every one gram of water increase per one kilogram of dry air the octane decreases by .25 to .35. WWII aviation engines used water injection and it worked well for a short time by cooling the cylinder temperature. As temperature goes back the effect goes away.
Old 10-18-2014, 11:53 AM   #14
awbrown
I usually peen them with a hammer , then use a good epoxy on them before I reassemble it ...
Old 10-18-2014, 12:32 PM   #15
danheit
danheit's Avatar
To the OP, a q-jet is a great carb. Most of the guys that are against them, don't understand them, or have had qjets that were improperly set. It is capable of great fuel efficiency, and can still flow up to 800cfm with little to no modification, when needed. As stated earlier, call Cliff. Another great place to start is Rochester.com. There's tons of replacement parts out there. Most likely you have a secondary electronically controlled power valve (the plastic plug on top of the air horn) and it probably isn't hooked up correctly. I would also guess that the choke and choke linkage is incorrectly or just not set up. Go on YouTube and start watching videos about rebuilding them. There's tons of info, and they're incredibly simple, once you understand them. If you look at stock class drag racers, a lot of folks still use them. Please know, this is a little of me talking out of my behind from memory, and a lot of personal experience. I grab one every time I find one in the junkyard. That and York AC compressors.....
1955 Chevy 3100 Task Force Pro Street - Sold!
1957 Chevy 3100 Task Force "Rat Rod" a.k.a. SLOTH - Sold!
1971 C10 Longbed factory A/C all stock 350/350
1979 Jeep CJ7 - Build date on the day I was born! -Keeper
2004 Expedition - Family Hauler
2007 Accord - Wife's around towner; I have more but not enough lines to post them!
danheit is offline   Reply With Quote
Old 10-18-2014, 01:18 PM   #16
geezer#99
geezer#99's Avatar
Here's a quick read on all things quadrajet!!
Study hard!
There will be a test!! LOL!!
http://www.digitalcorvettes.com/foru...ad.php?t=88376
Old 10-18-2014, 01:32 PM   #17
1971 GMC SHORTY
1971 GMC SHORTY's Avatar
Put a Holly 500 4412 thing will Pull Hard!
1966 GMC K25 V6 351E Original Utility Truck
2000 C3500 Hot Rod Utility Truck
2003 ROAD KING 100th 124ci 6 Speed
145CI M/P Pro Street FXR
2002 FXDP
2007 2500HD DURAMAX. DD
Studio Teamsters / Mechanic
Retired GM Master Tech 20 Years
Retired Ford Tech 15 Years
1971 GMC SHORTY is offline   Reply With Quote
Old 10-18-2014, 01:40 PM   #18
Figuarus
Figuarus's Avatar
Ok, I'm gonna start with Timing as suggested.
Changing out the carb isn't an option for me right now. I don't have much money to invest into it other than a rebuild.
i need to get my hands on a timing gun anyway, I will start with that and see where i'm at.
thanks for the info guys! i'll report back with results
2013 Malibu LTZ
Old 10-18-2014, 02:59 PM   #19
geezer#99
geezer#99's Avatar
When you get a timing light, get a dial back to zero or digital type. You might need to read your timing higher than the 12 degrees available on your timing tab.
Old 10-18-2014, 05:44 PM   #20
luvbowties
luvbowties's Avatar
Smile Re: Quadrajet Conundrum
I've seen & bought some good tune-up equipment on local Craigslist. Local lets you take a knowledgeable friend along to weed out the junk. Good and used quality equipment often is much better investment than brand new, low quality stuff.
sam
luvbowties is offline   Reply With Quote
elevation, jetting, quadrajet
