#151 |
![]() Join Date: Jan 2012
Re: How bout some pictures of '73-'87 regular cab dually
here mine all done
olyhotrodz
#152 |
It followed me home?
Bad ass!! ^^^^^^
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#153 |
#154 |
67-72 parts collector,…
![]() Join Date: Nov 2002
#155 |
![]() Join Date: Feb 2004
1988 V30 454/400 |
#156 |
![]() Join Date: Jun 2010
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
#157 |
You found yourself a nice one
#158 |
Yeah since you forced my hand and bought that one. Lol.
#159 |
You funny guy
#160 |
That's a real beaut!! Is that static dropped or bagged. If static dropped what kit did you use?? I'm contemplating dropping my dually
#161 |
#162 |
My dually, just put in a vortec 454/ th400. Needs lowered a lot, going to change rear ends from a 4:56 to a 3:73 Dana 70HD. Wanted to drop it while I had it all tore apart.
#163 |
Western chassis 3 inch drop springs and 3 inch drop spindle flip kit in the rear 2 inch shackle and c notch on 16 inch wheels
olyhotrodz
#164 |
Westerns c-notch or ??
#165 |
#166 |
![]() Join Date: Apr 2009
This Black Dually posted was SOLD a while ago......
#167 |
Charlie Daniels w/ a Tq Wrench
2012-09-08_17-19-23_926 by wrfalcon75, on Flickr DSC09882 by wrfalcon75, on Flickr DSC09910 by wrfalcon75, on Flickr Untitled by wrfalcon75, on Flickr
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
#168 |
#169 |
08 cc silverado dropped on 24's 82 1 ton c30 Dually |
#170 |
I have had this a month as of tomorrow. In that time I have put a newer mono on and changed the fluids. It runs, stops, and goes. The frame and drivetrain are all good and it is a great starting point mechanically.
I went from a 6060lb 12x8 steel/wood bed crew cab 84 with suspension set up to carry 2,000lbs to this little bugger. I can actually park this thing and even with the little 292 the thing gets up and goes. I am stockpiling parts now. I need to run it across a scale. Maybe it is all the wood/aluminum, less leafs, or the fact that most of the sheet metal is paper thin or gone. But I am guessing it is around 4500lbs. ![]() ![]() ![]() ![]() ![]()
1991 Metro commuter 1991 s10 future project truck 1987 V10 backup daily/junk truck 1985 K20 Winter beater 1991 R30(squarebody) c/c flatbed towrig 1994 s10 80"wb custom build |
#171 |
What size tires, and are they "E" rated?
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#172 | |
'77 Chevy K20 CHUMMINS '75 Chevy C20 Crew Cab (mostly) converted to 4x4 |
#173 | |
Tim K. 84 K30 srw Silverado 454 auto 85 C20 350 C6P auto flatbed 94 K1500 lifted shortbed 350 4 bbl NV4500 |
#174 |
Picked up this 1 owner 1973 a few weeks ago.
#175 |
Here's my 87
| Bookmarks |
| Thread Tools | |
| Display Modes | |
