Rear porterbuilt extreme kit panhard bar help needed
Ok so I'm setting up the rear finally. Says to put the bar in the furthest bottom hole and adjust at ride hight for equal width... My problem is with the 22's the panard bar is 3 degrees up at 5"ride hight. So when I go to lay it out the rear pulls to the drivers side about 1"-1 1/2". What can I do to keep the rearend within a 3-4 degree rAnge of motion through its up and down adjustment.
I don't think a wats link is the solution as there is t much room with the frame cross bar behind the reAr.... Any help or pics would be helpful. Thanks |
Hey good luck with trying to get a answer to your question from porterbuilt. Speaking from experience.
Re: Rear porterbuilt extreme kit panhard bar help needed
How much travel do you have from ride height to laid out? What is the adjusted length of the bar?
#4 | |
Nate@pbfab.com ???????????
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
Nate and Dave got me all squared away.. Nate refigered a rear notch cover to compensate. They've been a great help. Any questions or concerns I've had theve been on the ball. Thanks so much for your help Nate and can't wait to recieve the parts along with the new shock kit for the 60-66 c10 hood hinges.
Thanks again NATE and DAVE porterbuilt. You guys have great parts. |
