Old 10-19-2014, 09:39 PM   #1
!970C10540
Brake Upgrades
I just got a new frame with the factory 5x5 lug front disc brakes but missing the calipers and I was wondering is there any way to mount 4 piston calipers to the stock 11.84in discs or would the single piston be better in price and performance?
!970C10540 is offline   Reply With Quote
Old 10-20-2014, 05:13 PM   #2
Kook87
Kook87's Avatar
Re: Brake Upgrades
I don't think the 4 piston calipers will fit but I for sure know the single piston will not out perform the four piston. Contact Boris at Street Machinery and he can fix you up.
Don't sweat the petty things and don't pet the sweaty things.
Kook87 is offline   Reply With Quote
Old 10-21-2014, 06:36 PM   #3
66 C10 383
Re: Brake Upgrades
I inquired with Boris about some adapters to run a 2000 Vette Caliper on a stock truck rotor and was told it might be something in the future ...
Doug
Old Build Thread - 383/T56
http://www.67-72chevytrucks.com/vboa...d.php?t=540838
Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua
5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital
http://67-72chevytrucks.com/vboard/s...d.php?t=778784
66 C10 383 is offline   Reply With Quote
Old 10-21-2014, 10:24 PM   #4
!970C10540
Re: Brake Upgrades
what is the website.
Old 10-22-2014, 01:57 AM   #5
andrewmp6
Re: Brake Upgrades
I think they are talking about member way2lo2 http://67-72chevytrucks.com/vboard/s...d.php?t=465140
Old 10-24-2014, 10:15 AM   #6
!970C10540
Re: Brake Upgrades
thanks, I may get that summer next year, but right now I have 6 months to get the truck ready for my local autocross events and still have the floor to be replaced, frame/radiator support/axel housing to be powder coated, install the cab on the new frame, rewire the entire truck, wheels and tires, rear brakes, ring and pinion plus spider gears to be sent off for heat treating, find a long bed, get some driveshafts built, get a new custom cam built, and install the 540 and 400/gearvendors all before the second Saturday of April.
Old 10-27-2014, 10:06 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Brake Upgrades
The most economical upgrade to the stock caliper is the Wilwood D52 replacement. Several of our forum Vendors sell them at a reasonable price.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 10-27-2014, 11:01 PM   #8
!970C10540
Re: Brake Upgrades
But would it work with the factory size brakes or the Corvette ones?
Old 10-27-2014, 11:20 PM   #9
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Brake Upgrades
The 71 chevy truck caliper is a D-52 and they are a direct replacement. You can buy the pads locally if you want. The bigger rotors will not fit on a stock spindle from all my searching I have done.
The only way to get a bigger brake up front is buying a new set of spindles. Are have some one fab up whatever you need.
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 11-05-2014, 10:16 AM   #10
!970C10540
Re: Brake Upgrades
I am looking for a caliper bracket to bolt on a either Corvette 4 piston calipers or a aftermarket one because the size of the rotor is large enough for the budget minded builder, and with the stock calipers I`ll be running EBC greenstuff pads.
