Old 10-21-2014, 12:21 PM   #1
mark '87 930
mark '87 930's Avatar
engine removal question
you guys that have removed/installed engines into these second series trucks, do you remove the front grill/rad assembly, or do you use a cherry picker?
Just curious because that front end is very high.
If the front end comes off, how much work is involved?
I presume the hod comes off either way.
mark '87 930 is offline   Reply With Quote
Old 10-21-2014, 12:49 PM   #2
_Ogre
_Ogre's Avatar
Re: engine removal question
i've changed many with just the radiator and hood removed
i also pull the trans off the bell housing
stock trucks are easy because the truck sits high enough that you don't need to jack it up
makes it easy to use a chain fall, you can roll the truck out
when i did the last install in truk the frame was bare; no clip, no cab. made it real easy
shop air compressor timer
Old 10-21-2014, 02:11 PM   #3
OrrieG
OrrieG's Avatar
Since you have all the wiring, hoses, etc. all ready disconnected there are only 8 bolts holding on the whole front clip/radiator brace assembly. The stock six is long and heavy, especially with the cast iron bellhousing. Hard to do with a cherry picker with the fenders and grille on, ok with chain hoist and tall a frame. I have always just pulled the dog house, makes it easy to work on cleaning up the firewall, frame, etc.
Old 10-21-2014, 02:16 PM   #4
mark '87 930
Dog House = front grille/radiator/brackets?
Old 10-21-2014, 04:20 PM   #5
OrrieG
OrrieG's Avatar
Fenders, inner fenders, radiator support and radiator, grille (can be removed to make it lighter). Set it on the ground, add the hood and you have a place for the dog to sleep.
Old 10-21-2014, 04:24 PM   #6
mark '87 930
I've never heard that. It's actually very funny and i could picture it... I also don't know if you're being sarcastic or not!
Old 10-21-2014, 06:07 PM   #7
OrrieG
OrrieG's Avatar
google it, I'm not the only one that uses that term, been around since at least the 60's....
Old 10-21-2014, 06:35 PM   #8
mark '87 930
That's awesome. I'm gonna use that now.
Old 10-21-2014, 06:58 PM   #9
NEWFISHER
NEWFISHER's Avatar
Crawl in and take a selfy, then when the wife tells you " your are in the dog house" you get a hall pass to work on your truck
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-21-2014, 07:03 PM   #10
62lwbc10
I pulled out my 350 with TH350 attached with a standard engine hoist with truck at stock height. Had to help the tranny tail over the radiator area and had to max out the height of the hoist but it worked
62lwbc10 is offline   Reply With Quote
Old 10-21-2014, 07:18 PM   #11
G&R's57GMC
G&R's57GMC's Avatar
I've pulled my 6 with the hood and front clip, manifolds & bell housing ON, I just pulled the Rad and trans. (4 speed).
I needed to replace the cam timing gear.
Used a standard engine hoist with the truck sitting on its tires (stock height).
Glen & Jane's Rides
‘57 GMC NAPCO Long Bed V8 4 speed Bought 2008
7 other cars & trucks , 5 trailers
'56 Chevy Long Bed I6, 4 speed Bought 1990 Sold 8.22.2020
’56 GMC Suburban Pickup V8, 4 speed Hydramatic Bought 1996 Sold 10.11.2020
My Other Tinkerings http://67-72chevytrucks.com/vboard/s...75#post8967275
G&R's57GMC is offline   Reply With Quote
Old 10-22-2014, 10:18 AM   #12
mark '87 930
I'm totally doing that.
Old 10-22-2014, 11:06 AM   #13
Dan in Pasadena
Dan in Pasadena's Avatar
8 bolts?
2 where core support bolts to frame, one per side.
2 at top rear of fenders bolted to cab, one per side.
2 at bottom rear of fenders (?), bolted to cab one per side, I guess.
Where are the other 2?
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 10-22-2014, 01:42 PM   #14
OrrieG
OrrieG's Avatar
Inner fender panel to firewall.
Old 10-24-2014, 12:27 PM   #15
mr48chev
mr48chev's Avatar
I see no need to take the front end apart to remove it if you intend to remove it. Two guys can easily lift it off and carry it around. One guys with a cherry picker and straps hooked to the right spots for balance on the front end should be able to do it easily too.
Still mechanics in Chev garages never pulled the nose off these trucks to pull the engine when they pulled them out every day of the week. They usually used chain hoist at that time period too.
At home The big problem may be that your cherrypicker won't lift it high enough to clear the front. That could be because it won't actually lift high enough or the ceiling in the garage is too low.
If you do lift it out I'd take the waterpump off for clearance, unbolt the engine from the bellhousing (after you remove the clutch and flywheel) and lift it out.
My ongoing truck projects:
Old 10-24-2014, 02:22 PM   #16
OrrieG
OrrieG's Avatar
Actually not taking it apart is better because you do not need to deal with fitment issues when putting it back together. Just keep track of the location and number of shims at the radiator support bolt to frame, and upper and lower fender bolt to cab locations. In the 80's when I was younger and stronger myself and one other person could lift it off after the hood was removed. Dealers were usually just doing an R&R and not interested in cleaning up the firewall, frame, front suspension; all which is easier with the clip off.
Old 10-25-2014, 03:23 PM   #17
mark '87 930
I don't have a chain hoist and not sure i could easily get one in, but a cherry picker i can do. Is it possible/easy to remove one fender, inner and outer, and then just pull the engine out from the side? I'm thinking the hood and then the drivers side fenders...
Old 10-25-2014, 04:16 PM   #18
OrrieG
OrrieG's Avatar
Removing the fender is more work than the whole front clip....
