New engine, not so wonderful!
Got my new 35o from summit Tuesday, loaded in the back of my truck to unloade it in my basement where I was going to install it, my house is cut into a hill so it was and incredible challenge to get it in but I did it, pulled the old engine, uncreated the new engine and notices the valve cove was tweaked, the crate was perfect but the valve cover looked like a banana. Decided to pull the valve cover to check the rockers and found a broken exhaust valve. Called Summit, they're sending me a new engine next week but now I have no way to get the engine in front of my truck, you'd have to see the situation to appreciate it! There simply isn't a way of getting my truck out with out and engine in it. Before I noticed the broken valve I pulled the heads on the old engine to see if the block was cracked, it looks like it is, I have to reassemble my old engine, put it back in my truck, and get it out of my basement so I can pull the new bad engine out and load it in my truck so I can take it to exchange for a new engine then precariously get my truck back in my basement so I can do it all over again! You can't imagine the long string of absolute FOUL language that came out of my face when I realized all this! I am EXTRAORDINARILY LIVID! The crate was perfect, who ever slammed the valve cover hard enough to break a valve had to know they caused some damage but they crated it up anyway and let it get shipped!
http://smg.photobucket.com/albums/v655/aaronhero/ |
Re: New engine, not so wonderful!
I've learned to never, ever, remove old parts until I get the new ones to see if they are either correct or damaged.
1971 Cheyenne Super - Factory Big Block - Second (1987-89) & Fourth (2014-) Owner - To be restored 1978 Turbo Malibu - Owned since 1986 1987 Grand National Aerocoupe -1 of 1 1988 LeSabre T-Type - Supercharged |
Grumpy you sure love your emoji's lol and damn dude that sucks. I'd offer my help but I'm 2 time zones over lol I hope you get this sorted out. Make sure to take and post pics of the purty new power plant.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
Jeeze that's not what you want to see after all that work. Is summit going to give you some kind of compensation for the extra hassle?
![]() Join Date: Dec 2013
Seems someone didn't like them as much as I do as the are gone ? Wow I'm getting censored as fast as I post
This is why i do not use crate engines, build my own and i know what's in them , no suprises
That's a bummer! Any way you could somehow tow your truck out of the basement, then move your new/bad engine out of there? Hope you get it all worked out.
Yea, it sucks. Summit said "we'll talk after you get the new engine" as far as compensation. I doubt they do anything. The part that angers me the most is it's obvious it was damaged before it got crated up, it shouldn't have got out the door. I now wish I had taken my old engine the 80 miles to the closest shop but I had no idea if the block was any good. I needed the engine right away since this is my daily driver. I just have to figure out a way to get my truck out of the way to get the new engine in front of it, might just cut a new door in my wall but I still would have to get it down to the street down a steep hill. It's just a mess! All is not lost I guess, now I have a week to clean up my engine compartment.
#9 | |
Another crap part is I'm starting a new bussiness with my stepfather and I'm supposed to run several products on my cnc to show our client, supposed to have them done by Monday, to get my truck in my shop meant moving all my machines in the corner, in front of my CNC. I can't even reach the keyboard! I can't move all my machines because my truck and two 350's are in the way! It may cost me more than an engine at this point! I'm going to have to pay someone to run parts for me! Okay, enough complaining! Just needed to vent! Lesson learned, take crate off of engine before accepting delivery!
Maybe look into some of those car Dolly's that you can use to spin a car around and maneuver in tight spots?
Wish that would work but I have only 10" of space on either side of my truck and about six feet in front.
![]() Join Date: May 2012
Get the dollies like said and winch the truck out of there. You've no choice. Pull everything out of the work space and let it in there backwards next time and you can roll the engine right up to it. Or get 5 guys and push it out of there. Just get it out of there; and you will be feeling a whole lot better.
You're free to vent man and we'll all support you but the fact is, many of us have our share of "shop problems." Just take your time, think your plan through (very well), and get the job done. WHATEVER IT TAKES.
Show us pics of your basement if you like. |
#14 | |
#15 |
Bring over a few buddies and have a couple beers and someone will come up with a brilliant idea. Happens every time. Be sure to post your genius.
Or- you could show the thousands of us your situation and let us help you!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
#16 |
What brand of engine is it. Summit handles several brands of "crate" engines.
#17 |
All the labels say GM, I'm assuming it's from GM, most likely via Mexico!
#18 |
I think we got it solved, involves a new 6000 lbs front mounted winch, a sled, 12 beers, lots of cable and a cheeseburger. And more beer.
#19 |
Only one problem, I have to give them the engine before they would refund, can't get the engine to the street until I get my engine in.
#20 |
Been cleaning and painting all the mounts, brackets, pulleys. Just got done stripping 4 layers of paint of the intake with paint remover, it came out clean, I think I'll paint it black. The center port in the intake (for the lack of knowing what it's actually called) was nearly plugged with carbon, took a chisel and some heavy wire to clear it out. Been cleaning the quadrajet too. Tomorrow I'm going to clean up the wiring under the hood then clean the engine bay and paint it. I guess it's almost a blessing since I couldn't have done all this if I had just thrown the new engine in. Going to use my chrome valve covers and air cleaner since they cleaned up so nicely. Might even get a chrome timing cover. Makin lemonade.
#21 |
I am a Referee of life.
Get some trqula and limes and turn that lemonade into Margaritas!!!
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#22 |
Hang in there, it all works out. The factory crates these engines, not Summit. Summit would not have accepted it into inventory it if had a damaged crate. Summit got it that way from the distributor and will make it right.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
#23 |
Yea, they sent me a new engine, be here in a couple days. They're even letting me hold on the the damaged one until I get the new engine in my truck. At first they wanted me to take it to a GM dealer for repair, there is just no way to get it out of my shop so they sent a new one.
#24 |
Well thats good that there letting you hold onto the old engine till the new one arrives. Ive had the same hassels with smaller parts such as wheel cylinders that were off by a year, not i triple check everything like a madman. I hope this engine wont give you anymore issues.
1995 s10 blazer 4.3 1967 c10 350/350 fleet short 1993 s10 blazer 4.3l 4l60 RIP 6/20/14 2000 mercury sable Thats a how I roll |
#25 |
Finally got an electric fan!
![]() Actually I just degreased the engine compartment and trying to dry it so I can sand and paint. I was surprised how little oil and dirt was in there, I was prepared to use a putty knife to scrape it off but some simple green and a scotchbrite pad was all I needed
