01-21-2004, 01:56 PM | #1 |
What kind of lube do I use for my Rearend?
Not vasaline or KY.....
I noticed that there are basically 2 weights of gear lube. 80w90 and then there is a 85w140. I know the 80w90 will be better for the mileage, but will it offer enough protection? I do plan to use a synthetic gear lube, so maybe the protection worry is not a problem? Also, How many quarts do I need for a 12 bolt? Thanks Last edited by 68 Suburban; 01-21-2004 at 01:58 PM. |
01-21-2004, 02:07 PM | #2 |
Resident Curmudgeon
I alway have used 80w90 here in cold country. Last time I did this I bought 3 qts and used a little over 2.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
01-21-2004, 02:08 PM | #3 |
Too Many Clubs Club
The title of this thread is just ASKING for trouble! LOL
01-21-2004, 02:09 PM | #4 |
80/90 is the weight to use takes about 2quarts
01-21-2004, 02:10 PM | #5 | |
01-21-2004, 03:20 PM | #6 |
After I change the fluid I take it for a short drive and I check the level again, usually takes just a little more to top it off again.
71 Chevy CST Long Fleet 350/350/3.07 leaf rear. |
01-21-2004, 05:45 PM | #7 |
I'd check with the doctor on this one!
72 Cheyenne Super waiting on 4/6 drop,BB and 700r4 |
01-21-2004, 05:54 PM | #8 |
vasaline or KY.....
be a man.....use some SPIT |
01-21-2004, 05:55 PM | #9 |
Wiseass secured himself a BAN
80-90w here also. No synthetic.
01-21-2004, 07:01 PM | #10 | |
It followed me home?
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
01-21-2004, 07:27 PM | #11 |
All done lubing the rear. And might I say, my rear looked damn good
01-21-2004, 08:37 PM | #12 |
Live life and be happy.
I'll stay away from this one.
01-21-2004, 09:53 PM | #13 |
Why stay away from it, he just keeps asking for it................
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
01-21-2004, 09:57 PM | #14 |
PROJECT 7DEUCE
I use 80/90 valvoline..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
01-21-2004, 11:01 PM | #15 |
BlahBlahBlah
now thats a bad case of hemroids
01-21-2004, 11:18 PM | #16 |
one person said no synthetic....any reason, or just preference?
01-21-2004, 11:34 PM | #17 | |
01-21-2004, 11:41 PM | #18 | |
it's much thinner like motor oil and you are sure to get leak's... synthetic is supposed to be the hot ticket for race rear ends.. less power loss....less wear..... but in a old truck?????8.00 a qt.!!!!!!!!no new seals...i won't |
01-22-2004, 01:18 AM | #19 |
To late, and it was only $6.99 a quart Those rumors of synthetic wiping out seals have been around for a long time. I have never had a problem in any older vehicle that I have run synthetic products.
01-22-2004, 01:21 AM | #20 |
its all about the +6 inches
I swapped my rear over to synthetic too, and haven't had any problems.
I think the axle seals on my truck ar ethe only seals that DON'T leak. |
01-22-2004, 01:28 AM | #21 |
its true that it is the only seal that doesnt leak, or at least on my truck
my oilpan, my rear main seal, my ps gear box, my tranny, all leak but not my rear end!
70 longbed 496/th400/Ford 9" |
01-22-2004, 01:30 AM | #22 |
If its a posi don't forget to add the additive for the clutches!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
01-22-2004, 01:31 AM | #23 |
I've never had a problem running synthetic and in rear ends and transmissions (manuals of course). I always check the manuals I have before changing fluids too just to get a good idea of how much to get and what weight. Usually 80w90 for rears, fronts and trannies. If you have posi, always run the GM additive, never had any problems with that stuff, it's a little spendy but it really works.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
01-22-2004, 01:37 AM | #24 | |
