Old 10-25-2014, 11:43 AM   #1
joea307
joea307's Avatar
exhaust system interchange from shortbed to blazer.
I found a exhaust system slightly used from a 67-72 short bed truck.was curious if I could could use it on my 72 blazer.
joea307 is offline   Reply With Quote
Old 10-25-2014, 01:30 PM   #2
truckster
truckster's Avatar
Re: exhaust system interchange from shortbed to blazer.
If it's 4wd to 4wd, I don't see why not. You might need to shorten it a little bit before it goes over the rear axle, since the wheelbase is shorter.
I have no idea if 2wd to 4wd or vice versa would be as simple. I suspect if they followed the factory routing it would be no big deal.
truckster is offline   Reply With Quote
Old 10-26-2014, 05:08 PM   #3
skorpioskorpio
I would think the 2WD would more likely fit the 4WD than the other way around. Exhaust for a trailing arm 2WD Blazer is tricky but I don't see where it would be different than a 2WD short bed. Now trying to do what I want to do, which is a 3" side exit before the wheel and be above the frame rail the whole way, yep pretty tricky. Luckily with my inline I'll only have to do one side.
skorpioskorpio is offline   Reply With Quote
