dually stepside
I have a swb 71 350 and automatic. I plan on putting a dually rear axle in it and putting a step side box on it then extending the fenders. I was wondering if anyone has done that yet or if anyone knows anyone that has? I haven't been able to find one yet. Im new to the forum and want to say thanks
Re: dually stepside
I have a neighbor who put a dually axle under his fleetside and then used some step fenders as extensions.
Built not bought! My dad always tried to convince me HEI was pointless! Welding is a lot like sex, you don't have to be great with the rod as long as you thoroughly prep the surface and your good at grinding ![]() My build : 68 C10 Short Bed Conversion |
Re: dually stepside
Thanks I've seen a couple like that. By I have yet to see anyone do a short wheel base step side dually. When he went with that axlebdo you know if he still went with the coil springs or leaf? Im pretty sure those rear ends are built for leaf springs.
All about them K’s
![]() Join Date: Jun 2014
Re: dually stepside
You can buy dually adapters a lot easier than swapping the axle. Late model trucks use the same 14 bolt axle for both drw and srw. (Obviously some dually are dana 80s and not aam 14 bolts) but the adapters are what makes a dually not the axle is what I'm trying to say. My brother had an 88 light duty 6 lug 3/4 ton that someone put dually adapters and a dually bed on, so I know it can be done without an axle swap.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
Re: dually stepside
I actually haven't talked to the guy, I just see it parked around the corner in his driveway or on the street. I saw the hood up the other day, I was going to stop by and talk to him but I was on the way to pick up my kids.
Re: dually stepside
A friend of mind did a 81 dually short stepper a while back , had my hand in the original idea (hold my beer and watch this!). Used a long wheelbase cab & chassis , shortened , with the "narrow" dually rear , sectioned the bed in the middle instead of cutting the fenders , put about 6" in the middle , small tubs in the bed. Looked right , I have pictures somewhere if your interested. I would look at a normal 8 bolt rear with longer studs , could give the results we had - Good luck - Bob
Re: dually stepside
Found it
Re: dually stepside
#9 | |
Re: dually stepside
Hey if you drive up in a 67-72 pickup he might be a little more at ease. |
Re: dually stepside
Cab and chassis 14 bolts in squares used different hubs that made the wheel mounting surface (WMS) to WMS measurement narrower and better suited to DRW. I think the C&C used the same leaf pad center to center as the 67-72.
A tape measure and march through the scrapyard may get a 14 bolt that bolts in cheap. |
![]() Join Date: Jun 2012
Re: dually stepside
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
Re: dually stepside
If I were to get the dually adapters what should I get it goes up to 3".. At this point I feel wider Is better seeing I'm going to extend the fenders either way...
Re: dually stepside
Used to be done when there were heavy duty working stepsides around. Dodge used a spacer (similar to the pictures below) on the regular production fender and a dedicated step as I recall. Chevrolet to my knowledge did not offer dual wheels on 67-88 stepsides but it is possible. More likely any found would be from an upfitter or custom parts. Here are a couple of pictures for you to look over. One is period wrecker conversion with dual spacers and steps of unknown origin and the other was a mid 50's Chevy or GMC truck IIRC.
The biggest issue is why? Even then it was tough to bulk out all but the heaviest/densest loads in a stepside to really need duals, even on the C30/9'. If you are just going for a "look" consider the downsides carefully. If you locate a set of spacers or literature of any sort for a 67-72 or plan on tooling them please contact me. A dually CST/Cheyenne 30 4x4 9'stepside would be a cool hauler for the dogs.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
Re: dually stepside
Okay I found some adapters up to 3" which one would I want to get?.. (edited WTB) I want to do it because its different. I'm going to put a 12 valve Cummins in it with 5" exhaust all the way back. I want the exhaust to come out of the bed though not as stacks but out the tailgate. It will be different.
Please note that you must be a supporting member to post classified item. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here If you need any further assistance with that please contact any Admin for help. Last edited by oldiron; 10-28-2014 at 04:02 AM. Reason: Want to buy by non-subscriber |
