Old 10-26-2014, 08:31 PM   #1
67chevy1
67chevy1's Avatar
Rear End Question
What is the difference in a 12 bolt pick up rear end and a car rear end? I'm wanting to take the open carrier out of my 67 swb and put in a posi unit but seems to me all I can find is car carriers and they say they won't fit. Thanks in advance guys!!!
67chevy1 is offline   Reply With Quote
Old 10-26-2014, 10:03 PM   #2
oklalawnboy
oklalawnboy's Avatar
Re: Rear End Question
If I'm not mistaken, the pinion is smaller in a car rear end.
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 10-27-2014, 03:08 PM   #3
Fitz
The truck diff is an 8.875T(12 bolt truck) differential as opposed to the 8.875P (12 bolt passenger car) differential. Here's a drawing of the housing for each, looking at the housing with the cover off.
Drive train specialists has the unit you are looking for.
Fitz is offline   Reply With Quote
Old 10-27-2014, 03:19 PM   #4
turp mcspray
turp mcspray's Avatar
Truck rear has the smaller pinion. Trucks and cars have different ratio breaks for the 3 and 4 series. You will need a truck carrier.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 10-27-2014, 05:38 PM   #5
davepl
davepl's Avatar
If you look though my posts I listed the bearing combinations needed to make one work with the other (car posi carrier in truck rear end). I've never done it, but I found the information and shared it.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-27-2014, 09:05 PM   #6
hotrodder
Is the carrier different for a 3:73 and a 3:08? I am wanting to switch, and was told I would need to get a different one. I have a 67 with a 12 bolt. Thanks
hotrodder is offline   Reply With Quote
Old 10-27-2014, 09:08 PM   #7
67chevy1
67chevy1's Avatar
I'm pretty sure the carriers are the same no matter what gearing you have. I think there's just a difference in the housing between car and truck housings.
Old 10-27-2014, 09:16 PM   #8
hotrodder
Thank you for the info. Hope this question was along the same lines as the original one.
Old 10-27-2014, 09:16 PM   #9
crakarjax
crakarjax's Avatar
Not so, there is a carrier break at which the carriers are specific to the gear ratio.
OP, if you want to go posi a TrueTrac will get you there and replaces the carrier entirely.
1968 LWB C20 / AC / Wood Bed
crakarjax is offline   Reply With Quote
Old 10-27-2014, 09:26 PM   #10
67chevy1
67chevy1's Avatar
Ok that's exactly what I was looking for. Now for my next question I looked at summit for the true trac which one am I going to need? Is it the 8 5/8, 6"?
Old 10-28-2014, 09:05 AM   #11
crakarjax
crakarjax's Avatar
This is the one I got
Amazon.com: Detroit Locker 913A555 Trutrac... Amazon.com: Detroit Locker 913A555 Trutrac...EDIT: I think I got the passenger car version on accident, so don't get that one!
Here's some general info
http://www.drivetrainshop.com/GM_12_Bolt_s/105.htm
The one for truck rearends:
Amazon.com: Detroit Locker 913A315 Trutrac... Amazon.com: Detroit Locker 913A315 Trutrac...
Now, the website says this is only for 3.73 and up gears so if you want to run shorter gears (as I do -- 3.42) then you might be out of luck.
http://www.differentials.com/uncateg...-differentials
Old 10-28-2014, 12:13 PM   #12
hotrodder
Thank you for the correct information about the carrier difference. I now have a 2:73 gear and am wanting to change to a 3:07 but changing the carrier takes more money than I can afford to spend right now.
Old 10-28-2014, 12:32 PM   #13
jhwkns
Registered Cruiser
jhwkns's Avatar
Those use the same carrier as each other. I think the break is at .348
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 10-28-2014, 01:00 PM   #14
dell72
A truck carrier is longer ( wider) than a car carrier
dell72 is offline   Reply With Quote
