Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 10-28-2014, 09:28 PM   #1
Tzclark
Tzclark's Avatar
Need help choosing welder
Ok so I have narrowed it down to Lincoln 210mp and miller 211. My old welder was a Hobart with similar specs as these two but had a unfortunate encounter with a 30000lb forklift and its tire. I use the welder mostly for hobby and truck but on occasion take it to work for welding some supports for cable, or electrical equipment. Both welder have similar capabilities but the Lincoln is about half the weight which is what is catching my attention. Both are good brands.
http://www.millerwelds.com/products/...p?model=M00245
http://www.lincolnelectric.com/en-ca...roduct=K3963-1
1972 Chevy shortbox, done up 396bbc
1968 Plymouth Roadrunner, 1000hp twin 72mm turbos
2017 F350 Lariat, 6.7, stock except leveling kit and larger tires
2014 nissan pathfinder sl (the kid hauler)
Tzclark is offline   Reply With Quote
Old 10-28-2014, 09:53 PM   #2
tinydb84
tinydb84's Avatar
Re: Need help choosing welder
I dont think you could go wrong with either one. Why not another Hobart if you liked the last one?
David
Instagram: myfabguy
Old 10-28-2014, 10:06 PM   #3
Tzclark
Tzclark's Avatar
I can't find any stores that sell it locally anymore for some reason. I am leaning towards the Lincoln strictly for the weight savings.
Old 10-28-2014, 10:08 PM   #4
tinydb84
tinydb84's Avatar
I havent used the 210 but have used the 256 and liked it a lot.
David
Instagram: myfabguy
Old 10-28-2014, 10:13 PM   #5
mongoose
mongoose's Avatar
the miller isnt that heavy.. i have one and it's not a bad machine at all... if you really need to use stick over flux, or find a use for a dc tig which is a nice option get the lincoln.. I'd just try and find the cheapest one and go...
-'73 c/10 - Low with Go - will be complete... probably never.
-'90 2wd Blazer - well... soon enough anyways.
-'84 SWB - the daily gas guzzler.
mongoose is offline   Reply With Quote
Old 10-29-2014, 02:50 PM   #6
_Ogre
_Ogre's Avatar
they both look like good hobby welders
usually weight is directly proportional to duty cycle
but even at 25% duty cycle (at full amps) a hobby welder will rarely hit the duty cycle limit
i welded my whole truck up with a lincoln weldpak 100 fluxcore wire feed and never hit the 20% duty cycle limit
buy the one that your lws carries, they will become your best friend for life
shop air compressor timer
Old 10-29-2014, 06:12 PM   #7
tinydb84
tinydb84's Avatar
I have never hit the duty cycle on any welder. Maybe if I prepped all the joints ahead of time and did them I might get close...
David
Instagram: myfabguy
Old 10-29-2014, 09:31 PM   #8
_Ogre
_Ogre's Avatar
weld a bit, grind a bit, drink beer a bit, repeat
Old 10-29-2014, 09:58 PM   #9
Tzclark
Tzclark's Avatar
I am incredibly good at the beer part, welding.... Who cares about that
Old 10-29-2014, 10:54 PM   #10
dwcsr
Hollister Road Co.
dwcsr's Avatar
The miller is a mig welder the Lincoln is a multiprocess welder meaning its DC tig, stick and mig.
Old 10-30-2014, 09:39 AM   #11
PGSigns
PGSigns's Avatar
Not really the same types of welders so what is the primary use you are looking to fill. I have an older Miller 185 and it has been flawless since I got it. It has even been flooded by a hurricane. After going under I called Miller about what to do and they sent me a box of stuff to put in it at no charge. Best customer serve I have ever gotten. That was 11 years ago and it still welds good today. So my vote will be the Miller.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 10-30-2014, 10:38 AM   #12
Bigdav160
Bigdav160's Avatar
I like to TIG my sheet metal. There is a lot less metal finishing to be done when I TIG.
So if those were my only choices it would be the Lincoln
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 10-30-2014, 02:25 PM   #13
bs46488
I'd vote the miller. I just bought a Miller 180 and couldn't be happier.
I'm not sold on those multi unit products. I feel like you could do one process better than 3 things half way. Also, wont you still have to buy "extras" to have the ability to use all those features? (foot control, tig torch,etc) Also, doesn't tig use a different gas type? So that's a different bottle/regulator. So that will all increase your price.
bs46488 is offline   Reply With Quote
Old 10-30-2014, 03:41 PM   #14
dwcsr
Hollister Road Co.
dwcsr's Avatar
Mulitiprocess in that size is really just re branding the power unit. The same power unit is used for DC tig, Mig or Stick they just give you access to it all in one panel rather than 3 machines with the same power unit and different taps which would be very expensive. You will need the controls and an Argon bottle. Regulator is the same.
Old 10-30-2014, 06:04 PM   #15
Tzclark
Tzclark's Avatar
My primary use is hobby but putting when I do need it for work on occasion carrying a 80 pound welder with 10 pounds of wire and a bottle of its not flux core is a bit of a hassle
Old 10-30-2014, 07:03 PM   #16
dfrank
dfrank's Avatar
I would go with the lincoln. We have 8 lincolns and 1 miller which is a stick welder. Lincoln and miller are both the best welders you can get. The multi function on the lincoln is nice. We have only had one problem with a lincoln and that was with a 400amp portable diesel welder that a mouse got in and messed up the wiring. We have some that are over 25 years old and still get used everyday without any problems.
dfrank is offline   Reply With Quote
