#251 |
Re: 55 Wagon Progress
That's a nice collection of rides!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#252 |
A slight diversion, as the Migmaster 250 has left the building.....
![]() Sold it this past weekend on CL, time now to consolidate, where the old machine was a two-story deal, the new one will be a three story. In order to take up less floor space, I need to incorporate the Miller 211, the Hypertherm Tig, and the Snap On dent puller, and two bottles: ![]() ![]() ![]() Starting with the base, some 1-1/2 square tubing makes up the frame. This stuff was free, and as with most free stuff, it isn't. Kyle spent most of the time in the shop this evening media blasting rusty square tubing that has been sitting outdoors for a number of years. He also learned a bit more of mig welding.. ![]() The Tig will go on the bottom, and it has some mounting holes on the bottom side... ![]() So some 3/4 square stock was used to make some rails for the Tig, along with some holes to tie in the front end.. ![]() To be continued.... ![]()
Robert |
#253 |
Worked some more on the welder cart tonight. Started by adding the front casters.....
![]() A cross brace was added under the center line of the 2 bottles... ![]() 12 gauge will be used to form a tray under the bottles... ![]() Support bracket added for Mig welder: ![]() Next time we'll add the bracket for the dent puller... ![]()
Robert |
#254 |
![]() Join Date: May 2007
did you pick up anything from the auction ?
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
#255 |
I picked up a new shop clock at the auction.. My old Budweiser clock had quit about a month or so ago. This is a vintage neon Ford clock, looks to be a dealer only item as near as I can tell..
![]() ![]() Also got a small machinists tool box, primarily for the adjustable reamers it had inside, and the casters/wheels you see above for the welder cart..
Robert |
#256 |
Also got this crescent wrench rebuild kit that originally came out of a now closed hardware store. New jaws, thumbwheel/gears, and even vise grip springs (which I actually need a couple). Not items you're likely to see at a big box store..
Robert |
#257 |
never seen one those
#258 |
That' way up on the cool scale. Cresent wrenches are still the go to tool for changing torch gas bottles. And handy for bending stuff
#259 |
Never seen that before. Cool!
1952 Canadian Chevy 1300 C4 IFS & D44 IRS 5.3 HO L33 My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=632938 ![]() |
#260 |
![]() Join Date: Jul 2012
Very interesting....from the day when we repaired items instead of buying a new one.
#261 |
More progress on the welding cart tonight, the rear axle was made from a piece of angle and two 3/4-10 bolts..
![]() ![]() Rear bottle tray made from some 12 gauge, and welded on using about 3/8 diameter plug welds.. ![]() ![]() Top shelf added along with some gussets made of 12 gauge.. ![]() Bottle relief and pull handle added.... ![]() ![]() ![]()
Robert |
#262 |
Nice! That bottle must last you some time.
#263 |
They normally last a year or so..
Here's the rivnut installation video! https://www.youtube.com/watch?v=3jrrf_VbTsc .
Robert |
#264 |
More progress this evening on the welder cart, these studs are added to make use of the bottle bracket that came off the old welder. My brother in law had borrowed it at one time, and it came back with the fancy bracket. He retired the ratchet strap I had around the two bottles. This worked pretty well, so rather than reinvent the wheel.... Reminds me, I have some other things needing finishing I should lend him...
![]() ![]() ![]() Then a bracket for the clip is added to hold the Mig torch.. ![]() ![]() ![]() Holders for the various cables.... ![]() ![]() ![]() ![]() ![]() .....and a test fit before we throw some paint on it... ![]() ![]() Looks like I have some room left, may have to add one more....
Robert |
#265 |
Robert- great video on the rivnut installation tool. Thanks for posting that. Really nice cart you put together too. Well done.
#266 |
Nice cart!
#267 |
OK, one last welder to add and I promise I'm done...
![]() ![]() ![]() ![]() ![]() ![]() Now to disassemble and paint it...
Robert |
#268 |
Sweet! What colour?
#269 |
#270 |
Looking through the flam locker, here's what I have in LOUD. The neons typically don't like UV and are quick to fade, so I think it's between the Chrome Yellow and the Scarlet Red. I'm leaning toward the red...
Robert |
#271 |
Red, closer match to the Lincoln....
#272 |
Besides its a Harley color..
#273 |
Kyle worked this evening to repair the remaining damaged threaded holes in the inner fenders. A couple of the ones for the core support were stripped, so he changed those out to 5/16-18 rivet nuts.
![]() For the welded on clip nuts for the sheet metal style fasteners, we had drilled them out and installed 1/4-20 rivet nuts to be able to use machine screws instead. A couple of them popped off while drilling, and these were welded back on with the Miller spot welder to keep a good backing support for the rivet nut.. ![]() ![]() While he was working on that, I got busy adding some color to the welding cart. It was a toss up between some bright red (HD color) which was acrylic lacquer, or a bright yellow (H/K Lemon Yellow basecoat). As I didn't have any lacquer thinner in stock for the red, yellow it is...followed by clearcoat ![]() ![]() Along with the purple E-wheel, this should help to brighten up the shop!
Robert |
#274 |
skittles
#275 |
Well it was ether that or Patina then.. It will shine down a little with use.
