Old 10-30-2014, 03:51 PM   #1
ACII
how to get a rough idle ?
Hy all
i would like to get a sound / rough idle like this one =
Which cam / headers do i need to get a rough idle....
I know it just sounds a bit stupid but i dont care so much about driveability , the car is not a daily driver (more a show car).
So i am looking for a very rough / mean idle (sound)
Thanks Achim
ACII is offline   Reply With Quote
Old 10-30-2014, 05:08 PM   #2
Amr84ss
Re: how to get a rough idle ?
To me the best way to get the sound you want is to get with a company that can custom make you a cam. That way you can get the sound you want, plus whoever specs it out can match it to whatever else you have done to the vehicle. This way you will get the performance and sound you like at the same time. As for the headers, you would probably be good with running long tubes and some straight through type mufflers.
Here is a video of mine. I had the cam custom made for my wants and needs. The exhaust is crappy but it still sounds good.
Amr84ss is offline   Reply With Quote
Old 10-30-2014, 07:35 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
The simple answer is just get a cam with a low LSA. Lower lsa = "choppy" rough sounding cam. You don't have to go with a massive lift cam, just look for something with an LSA under 112. 109-111 is usually pretty snappy.
While the other factors (lift and duration ) will have an effect on the sound, the LSA will have the most cause-effect.
As an example, I'm running a TSP Tsunami w/ 111 LSA in my 6.0 This is a true dual exhaust (no crossover) with bullet-style mufflers (sometimes called resonators).
I don't know what you engine combo is off the top of my head, but on a mostly-stock engine, you can get any of the low-lsa cams to "chop" pretty easily. Keeping the idle low in the tune will make it even more pronounced (But will increase the chance of stalling or incurring misfires)
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 10-30-2014, 09:34 PM   #4
Amr84ss
BR3W is correct. LSA is the way to get the sound. My cam is a 111 LSA. I still need to have mine tuned to get the idle down some, and mine will sound better.
By the way BR3W, that truck sounds awesome.
Old 10-31-2014, 02:05 AM   #5
littlevictories
i played around with the idle under/over speed timing and some other tables to get a "ghost" cam effect.
was kinda fun for couple days. went back to dead stock idle coz i'm old.
littlevictories is offline   Reply With Quote
Old 11-03-2014, 04:12 PM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Another way to get it to "lope" a bit at idle is to lean it out. You can even get a stock cam to slobber a tiny bit if it's leaned out a bunch.
Regardless, this is a 112.5 LSA in my 6.0
And here is my current custom turbo cam with a 114+6 LSA
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 11-03-2014, 06:26 PM   #7
Custom 68
Custom 68's Avatar
Wasted, it sounds great, do you have any muffler or just your "turbo" muffler. I am guesing it is a straight shot...
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 11-03-2014, 09:25 PM   #8
Iceburgh
Iceburgh's Avatar
http://www.compcams.com/thumpr/
You give up a little in power but these sound great and are very streetable
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
Old 11-03-2014, 09:29 PM   #9
Iceburgh
Iceburgh's Avatar
1953 suburban build
