Old 11-01-2014, 05:51 PM   #1
Nordic
Nordic's Avatar
pinion/axle angle
Swapping in 3rd gen Camaro rear, the question is to get close to what I need for pinion angle - If I level the spring mounting pads how much angle should the pinion have?( as close as I can tell it s/b about 8-10 degrees ?)
58 step side 350/350
Nordic is offline   Reply With Quote
Old 11-01-2014, 09:19 PM   #2
geezer#99
geezer#99's Avatar
Re: pinion/axle angle
Here's a link on figuring out pinion angles.
http://www2.dana.com/pdf/J3311-1-DSSP.pdf
Old 11-01-2014, 09:34 PM   #3
roger55
roger55's Avatar
Normal engine tilt will be about 4 degrees down (with a level frame). If that's what you have, then match it with 4 degrees up at the pinion. So, check the engine first.
roger55 is offline   Reply With Quote
Old 11-01-2014, 10:03 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
This may be helpful in determining your angles
http://www.tremec.com/menu.php?m=154
