Old 11-06-2014, 07:41 PM   #1
ratrodsrule1
Yet Another Brake Question
I would like to convert a 67 C10 to the JB5 disc/drum configuration. I have been unable to locate a donor 1/2 ton with the JB5 system. What other year and models will have bolt in fronts and proper width rear end housing. I know I will need to weld different spring perches. It would be nice to replace the front crossmember/brakes as an assembly but if not i'll settle for just the parts.
We make too many wrong mistakes..................Yogi Berra
ratrodsrule1 is offline   Reply With Quote
Old 11-08-2014, 05:58 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: Yet Another Brake Question
You an swap complete 73+ front crossmembers by drilling a few holes. Several aftermArket manufacturers sell 5 lug axles to swap in your existing rear axle. Search the forum for more info.
WIDESIDE72 is offline   Reply With Quote
Old 11-08-2014, 07:19 PM   #3
mechanicalman
I checked your local craigslist and slim pickings for sure. I think you might consider staying with what you have and get a 6 lug front disk brake conversion kit such as this:
http://www.ebay.com/itm/1967-70-Chev...0e046c&vxp=mtr
I'm not saying get this specific one, but time you change out everything might be easier and even cost effective to just do something like this and more than likely you will have a better performing system.
mechanicalman is offline   Reply With Quote
Old 11-09-2014, 05:42 PM   #4
ratrodsrule1
Yeah Mechanicalman you're probably right and that's what I might do. But you know they say "it's not necessarily the kill but the hunt". I would still need to address the rear in order to have the 2 3/4 inch wide shoes. I know the burbs have the right size drums but not sure about the width of the rear end housing. Do you know ?
Old 11-09-2014, 05:55 PM   #5
mechanicalman
No, I don't but this forum should make short order work out of that, just do a search.
It's just that the market for used parts or even a donor vehicle seem dismal where you are. Are they all rusted away and junked?
I was going to suggest you get a donor 73-87 and take the front cross-member, booster/master, prop valve and rear end, as it seemed you were up to welding perches on what I assumed would be the rear end and convert to 5 lug. But I did a craigslist search for your area and did not turn up even one in the parts section.
You live in a tough neighborhood, parts-wise it would seem.
Old 11-09-2014, 07:44 PM   #6
ratrodsrule1
Yeah mechanicalman you're right about the rust, the humidity gets real bad in summer months. Every thing rusts here. So between the rust, cash for clunkers and the scrap prices were real high a couple of years ago a lot of them got scraped.
