Old 11-07-2014, 01:40 AM   #1
Truck Guy99
2wd lift kit?
I know I know, lifting a 2 wheel drive. Trucks an 05 chevy silverado 1500 2wd ECSB. Main reason for wanting to lift is clearance. Truck sees a few pastures but at stock height I often scrape it just pulling in to driveways. Truck never tows but is daily driver. Could i put a 2 inch coil spacer in the front and 1 inch rear block without sacrificing drivability? If so what is a good brand to go with?
My names Tye. No Chevy right now
Truck Guy99 is offline   Reply With Quote
Old 11-07-2014, 10:08 PM   #2
drivewaycustoms
drivewaycustoms's Avatar
Re: 2wd lift kit?
I think you'll be fine.
87 Crewcab Dually
66 Cadillac Sedan deVille
55 Chevy Belair
33 Plymouth sedan
03 S-10
86 S-10 Blazer
IG drivewaycustoms
drivewaycustoms is offline   Reply With Quote
Old 11-08-2014, 02:58 AM   #3
Truck Guy99
Re: 2wd lift kit?
What's a good brand? Considering these
http://www.ebay.com/itm/1999-2006-Ch...-/200694639009
Old 11-08-2014, 10:50 AM   #4
95 S_Trucker
95 S_Trucker's Avatar
Re: 2wd lift kit?
The coil spacer in the front will make the ride a little more harsh.
A spindle lift in the front would ride like factory.
95 S_Trucker is offline   Reply With Quote
Old 11-08-2014, 04:05 PM   #5
cubber
Re: 2wd lift kit?
Here's my 06 with a spindle lift and 2 inch blocks. I kept it like that for a month, then took it all off and put a drop shackle on the rear end. You might check, I think some ECSB trucks have torsion bars, which means you can adjust the height pretty easily by tightening the bolts, or getting different keys.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 05-24-2015, 03:48 PM   #6
Truck Guy99
Re: 2wd lift kit?
How hard is it to do spindles in a driveway? Any special tools?
Old 08-27-2015, 03:14 AM   #7
EddiesLow77
Re: 2wd lift kit?
Spindle lift is very easy remove ball joints tie rod and shock thats it you might need a ball joint sperator tie rod removal tool and you can rent these things at autozone
EddiesLow77 is offline   Reply With Quote
Old 08-27-2015, 03:45 AM   #8
Boats&Hoes
Boats&Hoes's Avatar
Re: 2wd lift kit?
Hi there! I work with suspensions and I know quite a bit in regard to lifting trucks.
The best way for you to achieve a mild lift and gain more clearance while maintaining a decent ride would be to, run spindles (Fabtech / CST) + a decent shock like Bilstein. I personally would leave the rear alone but either a block or add-a-leaf would be ideal, again pair either option with a decent mono-tube shock.
Spacers may be cheaper and they will successfully provide the lift you are looking for but unfortunately the ride is sacrificed.
Boats&Hoes is offline   Reply With Quote
