Old 11-07-2014, 06:48 PM   #1
BarnfindC10
Porterbuilt oil pan question
Looking to see what pan you guys are running on 5.3-6.0 lsx swaps?
BarnfindC10 is offline   Reply With Quote
Old 11-07-2014, 07:04 PM   #2
Fitz
Re: Porterbuilt oil pan question
MAST Motorsports LS conversion Pan.
Fitz is offline   Reply With Quote
Old 11-08-2014, 12:59 AM   #3
RaceAGMC
RaceAGMC's Avatar
That looks very similar to an F body pan.
70 CST, 6.0/ 4L80E in the works.
*Custom harness by 68 Short Step*
RaceAGMC is offline   Reply With Quote
Old 11-08-2014, 10:37 AM   #4
Fitz
Mast LS pan on left, F-body pan on right. As you can see, they are very different. I had to research this very carefully for a project in "anternate tinkerings". The steering rack in my riceburner was just too close to fit any of the stock GM pans so I used the MAST pan.
Old 11-08-2014, 12:49 PM   #5
BarnfindC10
So did your project rice burner have a porter built extreme front drop member?? I was more concerned with the pan clearance in the rear with truck is aired out. A truck pan is goin to be too low. I have an f body pan I can try. Just was thinking with all the Ls swapped porter built stuff I have seen out there someone would have crossed this road. The mast pan looks like the holley swap pan I used in a couple Tri fives to clear front cross member.
Old 11-08-2014, 02:42 PM   #6
Lees68GMC
Lees68GMC's Avatar
Challenges, we've delt with all kinds of oil pan sump clearance issue for years with LS motor apps and have never found a one size fits all oil pan solution. When you think an F-body pan or Corvette LS2 or 3 pan (pictured) will work you can still have interference problems because as the Sump depth is moved up (more ground clearance) it usually moves forward in design also too to retain the capacity (min 6 quarts) Heck the GTO pan has a Front sump. Different windage trays and pick-up tubes can be problematic also. Any and all of these can present problems with cross members, K-members and steering linkage clearances. Truck (Vortecs) sumps are always the deepest
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 11-08-2014, 07:22 PM   #7
Fitz
That's why I posted the dimensioned drawing so YOU COULD MEASURE YOUR PORTERBUILT DROPMEMBER! And, yes, I know I'm shouting! All you need now is a tape and some motivation. Put your motor in without any pan on it and get busy with the measuring tape because I don't think anyone here will measure it for you.
Old 11-08-2014, 08:07 PM   #8
BarnfindC10
Wink Re: Porterbuilt oil pan question
I have done over 40 Ls swaps(several stock c10 cross members) I wasn't being a guppie. Just trying to save time on changing 3 pans. YouTube unstang not my 1st rodeo(not yelling) lol
Old 11-08-2014, 08:21 PM   #9
cableguy0
Im gonna move this over to the ls forum in hope or more solid answers for you.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-08-2014, 08:37 PM   #10
Hart_Rod
Hart_Rod's Avatar
I have a F-body pan on my Porterbuilt extreme dropmember truck with no clearance issues. Fitz - the dimensions are hard to read on your diagram.
Hart_Rod is offline   Reply With Quote
Old 11-08-2014, 09:40 PM   #11
BarnfindC10
Thanks plan to put motor and procharger on tues fbody pan in the plans. Will add pics.
Old 11-09-2014, 12:04 PM   #12
Fitz
True, but a search for Mast motorsports will give you the 11 by 17 drawing which is legible.
Old 11-09-2014, 01:49 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
^this part will never happen, and I've been yelled at for thinking it was common sense before.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
