11-09-2014, 05:06 PM | #1 |
suspension help
I put 2.5 inch drop spindles and 1 inch springs on my 68 c10 and the truck has bad positive camber. Took all shims out and still has positive camber. The lower control arm barely clears the rim. What am I doing wrong here? Seems to me it should have negative camber if anything
11-10-2014, 12:19 AM | #2 |
Moderator
Re: suspension help
Moved this to the suspension board to get you some help
2018 Chevy Crew Cab 2006 Impala SS 1965 Plymouth Sport Fury 1970 Chevy Longhorn
70 Longhorn CST Build Adding an AM/FM Decal |
11-10-2014, 12:25 AM | #3 |
Re: suspension help
Thanks much appreciated
11-10-2014, 10:38 AM | #4 |
Re: suspension help
Pics?
Pos camber w/full weight on the front end? Wheel specs (size, backspacing)?
