Old 11-11-2014, 07:17 PM   #1
CARR33
Throttle cable,bracket problem
Putting throttle cable in my 67. Got a new 71 cable and engine mounted bracket. The cable is round where it is supposed to be held in. The bracket has a square hole with a slot in it to hold the cable. Am i stupid, missing something, or both. All of the aftermarket brackets have square holes.
CARR33 is offline   Reply With Quote
Old 11-11-2014, 08:31 PM   #2
JimKshortstep4x4
Re: Throttle cable,bracket problem
It appears that you have the wrong bracket. The bracket that you need has a round hole and all of the ones that I have seen are short with a pin that holds the bracket in place along with one mounting bolt. Here is a picture of one of the short ones with the round hole. The pin was missing on this one so I used a 1/4 screw as a substitute for the pin.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-11-2014, 08:36 PM   #3
CARR33
thanks, that was $40.00 for a bracket that was supposed to work with their cable.
