Old 11-11-2014, 10:53 PM   #26
dkauffman05
dkauffman05's Avatar
Re: Project 'Kickin Wing' (No Limits/Hotchkis/PorterBuilt/LS Power)
Any ideas on how your gonna brace the frame . I'm on that step now on my build just gathering ideas.
dkauffman05 is offline   Reply With Quote
Old 11-12-2014, 12:01 AM   #27
bterry97gt
Originally Posted by dkauffman05 View Post
Any ideas on how your gonna brace the frame. I'm on that step now on my build just gathering ideas.
I am still gathering ideas too but have a few things sorted out. I have steel ordered that I need pick up; I have a sheet of 3/16 plate, some 1 1/2" 16 gauge square tube, and 1x2" rectangle tube. I plan on boxing a few areas with the plate, two areas that i have noticed that have a lot of flex is the area from the trans crossmember up to the front suspension crossmember as well as where the frame starts to go up and over the rear end. I will probably add some corner gussets with the plate too.
I am going to have the no limits shock relocation kit and panhard bar in the rear. So really none of the factory stamped rear crossmembers will be used. I am going to replace all of them with the square tube just to clean things up a bit since I am going to be in this deep anyways. With the rectangle tube I am going to make a big X brace from where the original shock crossmember would be down towards the back of the cab. I will also add some braces onto the trailing arm crossmember.
But to be honest those are all just thoughts and my plan could change when I dig into it, and most of the ideas were taken from one of the Hotchkis trucks I saw. I figured if it worked for them it will definitely work for me. I hope to get started in the next week or so and will post pics of what we come up with. Here is a picture of the Hotchkis frame if you haven't seen it.
bterry97gt is offline   Reply With Quote
Old 11-12-2014, 12:30 AM   #28
Low68
Low68's Avatar
Cool build! Subscribed
Build Thread
Low68 is offline   Reply With Quote
Old 11-17-2014, 03:21 PM   #29
bterry97gt
Made a little progress this past weekend, managed to get the frame blasted and moved over to my parents house to start doing some of the frame work. I don't have the equipment or know-how to do this at my house so it will be there for a couple weeks.
In its temporary home getting checked for square:
Got some of the crossmembers cut out and got a rough layout of where the new tubing will be going. Nothing set in stone yet but this is close to what will be going back in:
Porterbuilt front relocators
Unfortunately, thats all I got done. Saturday went to waste because a buddy had a free UA vs MSU ticket that I wasnt going to turn down. So most of this was done on Sunday. I plan to hit it hard the next couple weeks because I dont want to keep it in my parents garage long. I have some off days coming up around Thanksgiving and hope to get most of it knocked out.
Roll Tide
Old 11-17-2014, 10:52 PM   #30
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Nice build, subscribed!
ChuckDriver is offline   Reply With Quote
Old 11-18-2014, 07:32 AM   #31
Elliot949
Elliot949's Avatar
Checking in to keep a eye on this...
Dan Johnston... Owner of My Dad's- '67 Chevy C-20 Custom Camper Short Fleetside Pickup PAPA J And our newest addition a- '71 Chevy CST/10 Short Fleetside Pickup Haulin' SOLD
Papa J's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=612847
Haulin's Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=671130SOLD
B Bears Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=744210
Elliot949 is offline   Reply With Quote
Old 11-21-2014, 11:22 AM   #32
bterry97gt
Well after adding up the cost of the upgrades I had planned for the original suspension I decided it would be best to spend a little extra for the No Limit chassis pack. By the time I added up brakes, spindles, springs, sway bars, AGR steering box, suspension rebuild kit, etc. it just made more since to spend more and know that I was getting a proven setup. Not to mention the benefits of rack and pinion, coilovers, and additional ground clearance that comes along with this kit. I did already purchase some parts with intentions on doing a few upgrades to the factory suspension, so those will be returned or sold. Here are some pics of the No Limit setup to those that are unfamiliar.
The only upgrades I added to the kit were the wilwood d52 calipers. I am scheduled to pick up the weekend of the 5th. I have got to start making some progress once I get the parts in or I am never going to get this thing finished While I am waiting I am going to get the rear end cleaned up and ready for the 4 link brackets, and whatever else I can do to not waste time.
Old 11-21-2014, 11:50 AM   #33
RUN GMC
RUN GMC's Avatar
Liking how this build is progressing.....hope to see it cruising around someday.........
RUN GMC is offline   Reply With Quote
Old 11-21-2014, 12:16 PM   #34
KMC3420
KMC3420's Avatar
No joke, this is progressing fast. Nice choice on the No Limit rack n pinion.
Keagan
68 SWB C-10 original 350 A/C 503 Mean Green
KMC3420 is offline   Reply With Quote
Old 11-21-2014, 12:23 PM   #35
Elliot949
Elliot949's Avatar
I don't mean to pry but what did the whole Front setup cost you...
Old 11-21-2014, 12:31 PM   #36
bterry97gt
Nolimit.net will give you an idea, a bit cheaper with the forum discount. It seems expensive until you start to add up all the little things, and I didnt want to have any regrets later on down the road.
Old 11-21-2014, 07:56 PM   #37
Nsanehotrodz
Nsanehotrodz's Avatar
We are running a holiday sale thru December 25th starting Monday!! Free shipping on all No Limit products including Wide ride IFS kits, Fatbar 4-Link rear suspension kits and No Limit aluminum Fuel tanks!!! This deal is only good when ordered directly from Nsane Hot Rodz! www.nsanehotrodz.com
customerservice@nsanehotrodz.com
865-761-0460
Tennessee's #1 HotRod Shop!
Nsanehotrodz is offline   Reply With Quote
Old 11-21-2014, 08:09 PM   #38
bterry97gt
Keep an eye out for a PM from me, I want to pick up a few sheet metal bits from you when i pick up my stuff from No Limit on the 6th.
Old 11-21-2014, 08:31 PM   #39
Nsanehotrodz
Sounds great!
865-761-0460
Old 11-23-2014, 12:31 PM   #40
HARDCORECASH
Subscribed to this build!! I just ordered No Limit Chassis Pack also......
HARDCORECASH is offline   Reply With Quote
Old 11-23-2014, 02:31 PM   #41
Low68
Low68's Avatar
Looking good! I like the suspension choice, but I may be biased...
Keep on keeping on!
Build Thread
Old 11-23-2014, 03:58 PM   #42
nlped
nlped's Avatar
I'm sub'd. You are moving forward pretty quickly. I like your plans for sure.
I've got to get my project(s) moving forward. Where did you get your frame sandblasted...did they prime it, or did you do that?
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 11-24-2014, 12:14 AM   #43
bterry97gt
Kreative koatings in Athens AL did the frame. They primarily do powder coating and ceramic coating but did the blasting for me. It hasn't been primed or anything, that's the finish straight out of blasting.
Old 11-24-2014, 12:24 PM   #44
nlped
nlped's Avatar
Cool, I'm going to give them a call after the holidays...
Carter
Old 11-24-2014, 12:27 PM   #45
HARDCORECASH
Free shipping would have been nice. I ordered directly from No Limit....😳
Old 11-24-2014, 01:36 PM   #46
bterry97gt
Keep on keeping on!
Haha, I just noticed the Joe Dirt reference. Thanks man, your build and fab work is inspiring to say the least.
Old 11-26-2014, 01:46 PM   #47
dodff1970
Junior Member
Love the build. I just bought a 67 and I think I might go the same route.
dodff1970 is offline   Reply With Quote
Old 11-26-2014, 09:25 PM   #48
swamp rat
swamp rat's Avatar
Also diggin the build and subscribed too.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 12-06-2014, 02:10 PM   #49
Bennett68C10
Bennett68C10's Avatar
Nice looking project, looks like your starting with a good looking truck and throwing some really nice parts at it.
Keith
66 Suburban
Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361
IG: bennett68c10
Bennett68C10 is offline   Reply With Quote
Old 12-08-2014, 03:20 PM   #50
bterry97gt
Well I finally have some updates. This Saturday I was able to make it up to TN to pick my suspension up from Rob at No Limit. While I was there I went ahead and bought some doors, rockers, cab corners, and a few other small parts from Dewayne at Nsane Hotrodz. I highly recommend these guys if you need any replacement panels or suspension components. They met us on a day they are usually closed and Dewayne showed us around the shop and let us look at some of the projects they have going. He also showed us areas where they have had fitment trouble in the past with replacement panels and what they usually do to fix the issue. It was about a 3.5 hour trip, but it was definitly worth it to see the parts before you buy. Not to mention the money I saved in shipping.
Here is a pic of the truck packed with goodies
