Old 11-12-2014, 07:46 PM   #1
thebebop
thebebop's Avatar
Hole under gas tank
Any idea what the hole under the gas tank is for? It's the large 2" hole just off center on the driver's side. I have searched through the manual and can find nothing on it.
I assumed some sort of grommet goes there but maybe a plug of some sort? If so what's it called so I can try and find one to purchase...
1955 2nd Series Truck
thebebop is offline   Reply With Quote
Old 11-12-2014, 07:57 PM   #2
OrrieG
OrrieG's Avatar
Re: Hole under gas tank
FAM page 8 2.00 shows it as an optional plug #444613 or 3719217. It was added after original production so maybe they thought about adding a drain to the tank, my stock one did not have one. I just welded it up. If you are going for a 100 point restoration the search is on, if not a little larger patch to cover the hole and seam sealer should work. patch in a little piece of round carpet and you are good to go.
Old 11-12-2014, 08:08 PM   #3
58CameoAZ
Believe that is for the Drain, My Truck had the same and the drain plug for the gas tank was set in the tank just above the same hole in the floor
Allen
58CameoAZ is offline   Reply With Quote
Old 11-12-2014, 08:11 PM   #4
thebebop
thebebop's Avatar
Cool my first though was it was for a drain but the original tank didn't have one so I tossed that idea. Looks like I'll just need to find a plug. Thanks for the info guys
Old 11-12-2014, 11:53 PM   #5
Denny55
Denny55's Avatar
You never wondered how the fuel got out of the tank and to the fuel pump!! There is a grommet that goes in that hole for the fuel line from tank to engine.
Brothers has them. Look under drivetrain, gas tanks, Grommets and gaskets.
Denny55 is offline   Reply With Quote
Old 11-14-2014, 09:30 PM   #6
yossarian19
Welder + steel or RTV + steel, your call.
"Over my head"
1957 Chevy 3200, big rear window & 6 lug.
Front disc, power steering, Vortec 4.8 / 4L60E swap, hydro boost brakes & patina.
yossarian19 is offline   Reply With Quote
