Old 11-13-2014, 01:29 PM   #1
Ozzy2013
Ozzy2013's Avatar
NV4500 overdrive 5 speed trans and bell housing
NV4500 for sale 1993 chevy bolt pattern all rebuilt by trans go in Philadelphia Pa.I have a lakewood blow proof bell housing drilled and tapped for the trans .The clutch fork is on the drivers side and has mounts for a hyd slave cyl or you can do manuel .I have a flywheel that goes with it .The tail housing is 13 inches long and uses a 400 turbo yoke with a mainshaft change it can be made 4wd .I was going to use it and went in a different direction.Prefer local pick up but will ship if you make the arrangements ill put it on a pallet i didn't get around to buying a clutch fork but they are no problem to get.Comes with the shifter also. . 1500.00 for everything!Thanks Oz
Ozzy2013 is offline   Reply With Quote
Old 11-23-2014, 09:38 PM   #2
Ozzy2013
Ozzy2013's Avatar
Re: NV4500 overdrive 5 speed trans and bell housing
Still for sale folks !
Old 12-24-2014, 03:19 AM   #3
Ozzy2013
Ozzy2013's Avatar
Whole set up for sale 1,200!End of the year sale my loss your gain need to make room .For sale or trade for a good posi rear.
Old 01-02-2015, 01:08 AM   #4
Ozzy2013
Ozzy2013's Avatar
For sale folks Blowout price of 1,100.00 Or consider truck parts in trade let me know what you have.
Old 01-02-2015, 04:48 AM   #5
kda2000
kda2000's Avatar
I'm interested, and shipping can be handled, but can you answer a couple of questions: Will this bell housing use the motor mounts on our trucks, or does it need a trans cross member? Does this have a mechanical or electrical speedometer output? Do you have the receipt from the work done by the trans shop? Thanks, Ken
kda2000 is offline   Reply With Quote
Old 01-02-2015, 09:11 PM   #6
Ozzy2013
Ozzy2013's Avatar
No it was rebuilt when i bought it and i didn't get you can pull the cover off and see its all new.It has a VSS electronic speedo hook up.I was going to use a converter or a electronic speedometer .The gps speedos are nice also .You could always change the main shaft also.I was going to use a trans cross member this is a Lakewood bell housing and it has bolt holes that look like you could bolt it in our bell housing mounts if you wanted to .Hope all of the info helps .Oz
Old 01-03-2015, 12:17 AM   #7
kda2000
kda2000's Avatar
Thanks, I'll need to do some more investigation before I can commit. But thanks for the info. --- Ken
Old 01-03-2015, 12:57 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
Is the flywheel for a one piece or two piece rear main block.
Thanks,
LockDoc
Leon
Old 01-18-2015, 12:04 PM   #9
68gmcdually
68gmcdually's Avatar
Here's a bump, I run this transmission in my '68 and love it, I haven't had a speedometer since I built it, what sort of converter box would you recommend? My father was looking at one while at a trade show back in 2009, but unfortunately passed away shortly after his return and I never took it any futher.
James Bellwood
1968 930 Extend-A-Cab Dually 5.7l, 5 speed,
68gmcdually is offline   Reply With Quote
Old 01-24-2015, 01:09 PM   #10
LockDoc
LockDoc's Avatar
Check into the SpeedHut GPS speedometers. I used one in my '67 with an S-10 5 speed and it works really well.
LockDoc
Leon
Old 05-10-2015, 12:39 AM   #11
Ozzy2013
Ozzy2013's Avatar
this set up is sill for sale.
Old 05-10-2015, 04:46 PM   #12
LockDoc
LockDoc's Avatar
I posted a question in post #8....
LockDoc
Leon
Old 05-10-2015, 05:26 PM   #13
Ozzy2013
Ozzy2013's Avatar
The flywheel is for a 1969 396
Old 05-10-2015, 07:17 PM   #14
LockDoc
LockDoc's Avatar
Thanks.
Man, I wish you were closer I would love to have that setup for my '67 C-30 Dually.... I'm not sure how to figure shipping on something like that. Or even if it could be handled from this end. Do you have a "Fastenal" store anywhere near you?
LockDoc
Leon
Old 05-10-2015, 08:05 PM   #15
Ozzy2013
Ozzy2013's Avatar
Yes we have one right down the road from my house.The bell housing is a blow proof and they sell for over 400.now!I got a deal on a TKO500 thats the only reason im selling this set up i have a lot more in it then im selling it for.
Old 05-10-2015, 11:43 PM   #16
LockDoc
LockDoc's Avatar
OK, thanks. I will check with my local (17 miles away) Fastenal on shipping but I won't be able to until Tuesday. I will probably need a weight estimate on the parts. If you sell it before then I will understand.....
LockDoc
Leon
Old 05-11-2015, 06:28 PM   #17
Ozzy2013
Ozzy2013's Avatar
The trans is 195lbs dry and what ever the fly wheel and blow proof weighs you can google it or guess .Id think 250-300 would cover it .
Old 05-11-2015, 08:33 PM   #18
LockDoc
LockDoc's Avatar
OK, thanks. I will check with them tomorrow afternoon.
LockDoc
Leon
Old 05-13-2015, 10:45 PM   #19
LockDoc
LockDoc's Avatar
PM sent on shipping and payment details. If you are agreeable to Paletizing and delivering to local Fastenal branch, I will take it for 1,100.00....
Thanks,
LockDoc
Leon
Old 05-15-2015, 09:03 PM   #20
Ozzy2013
Ozzy2013's Avatar
Sent you a PM back and its yours !I will get your info and payment and get it on a pallet ready for shipping .Thanks !
Old 05-18-2015, 08:44 PM   #21
LockDoc
LockDoc's Avatar
Payment sent for NV4500, scattershield, & flywheel.
Thanks,
LockDoc
Leon
Old 05-18-2015, 10:40 PM   #22
Ozzy2013
Ozzy2013's Avatar
Thanks lockdock!And thanks gmcdually for the bump i was real sick from December untill just a few weeks ago fighting several infections .And wasn't on the forums much or wouldn't have taken so long to get back with everyone.
Old 05-22-2015, 01:07 AM   #23
Ozzy2013
Ozzy2013's Avatar
Watching for the payment in the mail will ship when i get it .Have a great holiday weekend.
Old 05-23-2015, 10:51 PM   #24
Ozzy2013
Ozzy2013's Avatar
Got the payment and talked to my local fastenall and they said to drop it off Tuesday morning due to the holiday .Will do thanks for the sale .Oz
Old 05-23-2015, 10:55 PM   #25
franken
I'm curious about the packaging/palletizing and cost to send via Fastenall. Can you provide details? I filled out a form to ask about shipping a transfer case on the Fastenall site and never heard back...
