Old 11-14-2014, 03:15 PM   #1
Fastest32
Fastest32's Avatar
newer model 250 fitment
So the 250 in the truck is out of a 72 nova as far as I know. I need to replace it and found one on craigslist. It's in a 77 pick up and they guy is swapping it out for a 350. Does anyone know if I can just swap them over with no issues?
BaBaBooey BaBaBooey
GO SPURS GO!!!
Fastest32 is offline   Reply With Quote
Old 11-14-2014, 03:58 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: newer model 250 fitment
The 77 is likely an integral head (meaning the head and intake are cast as one piece) which is not desirable. The blocks are basically the same and will swap but I would swap your 72 head over. If the 77 is a standard head with separate intake and exhaust manifolds, then you wouldn't need to change anything. All of the 194, 230, 250 blocks mount the same. The 292 had different engine mounting point on the pass. side.
Hope that helps.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 11-14-2014, 05:27 PM   #3
Fastest32
Fastest32's Avatar
Hope that helps.
helps a lot. Thanks. How can I make sure it's a 250 and not a 292?
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 11-14-2014, 06:23 PM   #4
Fastest32
Fastest32's Avatar
Well it looks like the intake is cast with the head. Bummer.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 11-15-2014, 03:25 PM   #5
NEWFISHER
NEWFISHER's Avatar
Look at your 4" side covers and the 77. If the same then they are the same. Swapping the head is easy. You will need 5 of the original headbolts( integral bolts too long on manifold side) a gasket set and reuse your intake exhaust and valve cover. Tstat housing may be different and you want to run your old one. Get a new tstat. Oil , coolant and swap it out.
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 11-15-2014, 04:17 PM   #6
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
I'm running an integral head motor . If you swap that head be sure and do it somewhere you have help or the engine is close to the ground . I weighed that head and it's 140 lbs. Huge pain to drag out with the engine in the hole .
powerdriver 1958 is offline   Reply With Quote
Old 11-16-2014, 05:39 AM   #7
Fastest32
Fastest32's Avatar
I think im gonna use my old head on it. I want to reseal everything on the motor and paint it up nice. Not sure how nice I can get it with that integrated head. Might have to wait til next weekend to go get the the motor but the guy said he'd hold it for me. Hopefully nobody else snags it up. From the pics it looks like it has electric choke. I'm stoked about that. Hopefully I can use that carb with my intake.
BaBaBooey BaBaBooey
GO SPURS GO!!!
Old 11-16-2014, 05:40 AM   #8
Fastest32
Fastest32's Avatar
Thanks for all the info everyone
BaBaBooey BaBaBooey
GO SPURS GO!!!
