Old 11-16-2014, 12:28 PM   #1
KQQL IT
At the body shop.
KQQL IT's Avatar
sm465 swap options
Looking at a 91 r3500 2wd with a granny low 4 speed.
What are my 5 speed swap options?
Old 11-16-2014, 01:26 PM   #2
bluex
bluex's Avatar
Re: sm465 swap options
Sticking with a heavy duty trans if you are going to tow with it an nv4500 is the heavy duty 5 spd.
bluex is offline   Reply With Quote
Old 11-16-2014, 03:08 PM   #3
Gregs71
Ranger OD unit?
1995 GMC 4x4 1/2 ton
1999 Jeep Wrangler w/ 33's
68 camaro 350/350
1987 Chevy 3/4 ton 4x4
Suzuki DRZ 400s Dual Sport
1971 chevy long bed 2x4
194? Dodge 2.5 ton
1980 Chevy Cheyenne 4x4 1/2 ton I6/sm455
1989 Chevy V30 crewcab dually 454/TH400
Gregs71 is offline   Reply With Quote
Old 11-16-2014, 03:51 PM   #4
Tom
driving is in my blood
Tom's Avatar
Anything you want? Your swapping, so the possibility's are endless.
Old 11-16-2014, 04:01 PM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Easy(er) swap.
Same bellhousing and clutch
Old 11-16-2014, 07:39 PM   #6
83swb
Your only real option is going to be an nv4500 out of a gmt400. The nv3500 probably wouldn't hold up to a 1 ton truck. Could find a clark 5 spd out of a c60 but good luck finding one, plus the final drive difference probably wouldn't gain you much compared to an nv4500.
83swb is offline   Reply With Quote
Old 11-17-2014, 02:05 AM   #7
Cabnchassis
As far as I know all the R3500s in those years are Cab and chassis just as an FYI. Which means corporate 14 rear, different frame thickness top to bottom (over 9" tall on C&C and like 6" on a regular truck) and different than standard frame lengths on regular cab models. All crew cab cab and chassis models are 56" cab to axle same as any longbed pickup. Single cab models are 60" and 110" IIRC but neither will fit a standard bed. The registration will be more expensive if it is a C&C and registered at a higher than 10K GVWR. The corporate 14 dually is substantially narrower than a standard chevy dually with a dana rear end. Narrower to the point it fits under a fleetside bed and would not accept a regular dually bed. You may have known all that already but I'm a ford guy by raising I know when I bought my 91 I didn't have a clue it was anything but a regular old gmc 3+3 dually with a flat bed.
As far as swapping the NV4500 is the only way to improve on it in a manual without getting into pricey aftermarket or custom stuff. Unfortunately they always go for premium prices even used because of people just like us wanting to swap one in.
1991 R3500 3+3 C+C 6.2/4l80e/14ff Fleetside Dually
1992 K2500 ECLB 5.7/4l80e/14sf(g80) 8600gvwr
1991 CR500 (95 Burb wouldn't stop catching fire )
Cabnchassis is offline   Reply With Quote
Old 11-17-2014, 02:35 AM   #8
KQQL IT
At the body shop.
KQQL IT's Avatar
It's for this.
Was like this before.
Just want a better shifting all sychro'ed 5 speed
Going to be my beater.
Old 11-17-2014, 02:49 AM   #9
Cabnchassis
If it is cab and chassis the rear end was swapped or it was born as a single rear wheel truck.
Great looking truck and hard to find with a real bed and single rears.
The NV4500s come up on CL all the time but they usually need a rebuild if the price is decent. It's really your only option. Sometimes you find them in wrecking yards, but don't plan on it.
Old 11-17-2014, 11:25 AM   #10
KQQL IT
At the body shop.
KQQL IT's Avatar
It was born a single rear pickup truck. Has a 10 bolt and 1/2t spindles.
Old 11-17-2014, 12:39 PM   #11
Cabnchassis
Definitely a cool truck. I could probably count the number of srw crew cabs I've seen in person.
