Old 01-23-2004, 03:28 AM   #1
WB72
Before and After
WB72's Avatar
Factory bench Question
The rigid wire that connects the two sides of the mounting brackets has been taken off.
I want to put it back on, I think I remember that it went through some hog rings, is that true? If so how many?
The wire is too long if it doesn't.
I know that I don't need it if I don't want to adjust the seat, and Iprobably won't adjust it, I would just like it back on.
Photos?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-23-2004, 04:03 AM   #2
gonebad2
Merciless Butcher
gonebad2's Avatar
That sounds right. The hog ring was used to keep the wire up and out of the way.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-23-2004, 04:15 AM   #3
GMCPaul
Actually there should be a small metal loop attached to the bottom of the seat springs midway across the bottom of the seat that it slides through before connecting on either side.
GMCPaul
GMCPaul is offline   Reply With Quote
Old 01-23-2004, 10:44 PM   #4
WB72
Before and After
WB72's Avatar
Does it go through just one hog ring?
66,000 miles.
Alberta, CANADA
Old 01-24-2004, 12:06 AM   #5
Alex Hayley
Mine goes through only one hog ring...if it still has too much slack to adjust the seat back and forth, put it through another hog ring.
Alex Hayley is offline   Reply With Quote
