Old 11-17-2014, 11:21 PM   #1
Cam-Shaft
17 and Buying a Truck! '72 C20 4X4
So I am 17 and buying my first truck. I have a deal worked out for this and will be picking it up within the next few weeks. It is a 1972 C20 with the 327 and Manuel transmission.
Some questions I have:
1) Why is it four wheel drive? I thought C stood for 2 wheel drive, but it is obviously four.
2) Why is the grill kind of unuiqe? I seem to find another truck that has the chevy emblem on the hood instead of the grill.
3) What transmission does it have? I think its 3 speed with a granny? not to sure on that.
Let me know what I've gotten myself into! I like the look of this old beaut and look forward to learning more about it.
Cam-Shaft is offline   Reply With Quote
Old 11-17-2014, 11:25 PM   #2
OlSmokey
Re: 17 and Buying a Truck! '72 C20 4X4
Well I can definitely answer your second question.
It's because the ones with the Chevy emblem on the front is exclusive to 1972 trucks. Same with the plastic grilles.
(PS. This is coming from a fellow 17 year old with a 1972 C10 Good luck with it and have fun!)
OlSmokey is offline   Reply With Quote
Old 11-17-2014, 11:26 PM   #3
Cam-Shaft
Thanks for the answer, I appreciate it!
Old 11-17-2014, 11:51 PM   #4
Nitis
Nitis's Avatar
Actually 71 had bow tie in grill also
I doubt it's a 72 doors are wrong and too many 69/70 correct items like fender badging and grill.
If it's a true 4x4 it will have a K in the beginning of the vin
Looks like a project for sure good luck!
Nitis is offline   Reply With Quote
Old 11-17-2014, 11:54 PM   #5
TheCougarine
TheCougarine's Avatar
1971 trucks also had the bowtie in the grille. Your truck seems to have a 69-70 front, are you sure its a 72?. Also from what I understand all trucks had c10 c20 ect. badges regardless of 2wd or 4wd. But anyway 4wd would make it a k10 which the vin would tell you.
Edit Nitis beat me to it haha
TheCougarine is offline   Reply With Quote
Old 11-18-2014, 02:16 AM   #6
67swb72klb
67swb72klb's Avatar
a 72 will have disc brakes on the front
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project
67swb72klb is offline   Reply With Quote
Old 11-18-2014, 02:27 AM   #7
In The Ten Ring
You've gotten yourself a can of worms but so has just about everyone else on here.
Front end is definitely 1969 or 1970. 327 was not standard for 1972 although I could easily be wrong.
What I like about your truck:
1). It's going to be yours. That's the main thing. If you utterly have a fail there it's still your fail and you can part it out.
2). 4wd. I wish mine was.
3). Long wheel base. I wish mine was.
4). Manual in floor....I sometimes wish mine was.
5). Bench seat. Bench seats ROCK. My truck has a bench seat and let me tell you, when I was in high school and driving my truck on dates.......BENCH SEATS OWN. If you can't figure out why.......your GF will know I bet.
6). You have a 327. People go nuts over that engine.
7). You have 4 matching hubcaps and what appears to be a spare wheel. That's very good.
The real bad:
1). Does it run? Does the engine turn over by hand?
2). You have a cracked windshield but people replace those and people on here will help.
3). You've got bad rust going on but again, people will help and it's common. My truck is full of bondo actually from likely the same amount of rust.
There's my 2 cents (.25 cents actually). LOL
Congrats man and I hope you enjoy it.
In The Ten Ring is offline   Reply With Quote
Old 11-18-2014, 02:28 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Welcome to the boards! Most of your questions have been answered and you'll probably have more.... you found the right place, there's an awful lot of knowledgable, helpful folks here. Unless the front clip has been changed, it looks like a 1969 or 1970. Check the front brakes -- '71 was the first year for front discs. Probably has a 4-speed with a granny low. Can you post a pic of the SPID?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 11-18-2014, 02:59 AM   #9
68350
68350's Avatar
I can tell from pictures it has half ton axles for sure. Like others have said, it appears to be a 69 or 70 body. What's the first part of the Vin number(no need to post the last 6 which are the sequence number). If you look at passenger side of the motor, there will be a flat area right in front of the head. There should be a 2 or 3 digit code which will decode the engine. Most likely a 4 speed(3 speed with granny low). Looks like a sweet start!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets
68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction
69 Chevy Camaro SS, 383, 4 speed, positraction
70 Chevy El Camino SS396, Triple Black, 454/th400, Tach
70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks
70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR
71 Chevy Blazer, CST, 350/auto
71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s
71 Custom/30, Open Road, 350/th400, tilt
72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi
72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi
68350 is offline   Reply With Quote
Old 11-18-2014, 03:26 AM   #10
mechanicalman
I don't see a rear view mirror hanging down from the top of the truck. If it has screw-holes from the mirror being removed, then it's likely not a 72. If it does NOT have any evidence of ever having a rear view mirror, then it was at one time glued onto the windshield and the cab is a 72 for sure. I'm talking about the mirror that goes between the visors.
It could simply be a C20 front clip on a C10 72 4WD.
BTW, how do you know it's a 327? Can you take a picture of the inside of the glovebox door and post it?
mechanicalman is offline   Reply With Quote
Old 11-18-2014, 08:56 AM   #11
72MARIO
72MARIO's Avatar
Looks like a 67 glove box door too. Great truck to start with does it have disk or drum brakes up front ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 11-18-2014, 10:56 AM   #12
Cam-Shaft
Wow! Thanks everyone for the response! Last time I looked at it I didn't pay too much attention to the details, I was in a rush and just took the pictures. I am going thursday afternoon to really see what I am getting into. Hopefully it will be coming home this weekend or the next!
The engine does run, he said it is in great condition. I know it's missing a few parts, will my parts off my dad's old 350sb fit on it?
I will definitely be asking how to replace the windshield and take care of the rust. I'm looking forward to this project and the support offered here! I will take down the vin number when I go back as the guy (scrap yard) could very well have gotten the year/engine size down wrong. It will be a winter project, my goal is to have it road worthy and looking good for early may.
Again, thanks guys! I'll let you know what I find out!
Old 11-18-2014, 11:55 AM   #13
MARKDTN
I doubt it's a 327. All 327s had oil fill into the intake. I know you can swap valve covers, but I bet it's a 350. Really makes little difference anyway. Most small block parts will bolt right on either one.
The rust looks bad in the photos. At least 1 door, fender, both rockers. Can't tell in the interior shot if that's rust above the drivers visor or what.
Few tips for you:
1-be sure you can get a clean title, junkyard cars CAN be tricky to get back on the road depending on how long off the road, how obtained, leins on title, what kind of business they are, bill-of-sale in a title State, etc. All of that can be overcome with enough time and money but take that into account.
2-if the cab is rusted above the visor, I would look for something else. You probably don't want to do a cab swap. Also look at the frame. Be sure the frame isn't rusty. Floors look OK, but how about cab corners?
3-how is the front axle and transfer case? 4wd is a whole another world.
4-why was it parked?
Mind if I ask how much this jewel costs? I have nothing against this deal if that is what you want. If it is as bad as it kinda looks you will learn a lot about body work and mechanicals. When I was 17 I could have handled this project. Some can't and it burns them out to working on cars for a lifetime. I guess all I am trying to say is know what you are getting into. Be prepared for it to cost 2-3 times what you estimate.
Again, if you know that is what you want and are prepared to do it. Go for it.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-18-2014, 03:06 PM   #14
mechanicalman
Yes, parts off a 350 will fit. Regardless of what you were told, if you can't verify the engine's condition, it's not wise to pay more than the price for a salvage core. Sounds like you want to hear it run before you buy it? Good move.
According to my research, 327 engines were still manufactured in 69 but I don't think they were offered in trucks that year being replaced by 350's. I am 100% sure you could get them in Impala's and Camaro's. IF you can get to the back of the engine on the block just below the back of the driver's side head and get the casting number we can identify it for you.
Make SURE the title matches the VIN on the door jamb drivers side. Also, according to some posts on this forum, some states require that the frame numbers match too, but I don't know which one/s but it seems to be east coast.
Mixed/matched parts can still make a nice truck but you have to have title to whatever parts are required to match numbers wise.
If it's as rusted as I think it is, the cab will probably not be save-able. Take a good look at the area around the windshield, floor, etc. Usually a rusted windshield surround means leakage and leakage means a rusted out firewall. That driver's door looks like it's about gone, I'd look her over real well.
Check the frame for rust/cracks especially around the leaf spring perches (mounts).
If you are serious about buying it, bring a friend and take "X" measurements on the frame rails. The "X" measurements for the entire length of the frame need to be close to equal but talk to another board member or a body/frame man to know how close they need to be.
Beware all the rust.
Beware correct title/vin.
Beware frame condition.
IF it's as rusted as I think it is, and IF the price is right (I mean really right) it might make a good parts truck IF you want a 4WD.
Old 11-18-2014, 03:26 PM   #15
mechanicalman
That's a 4 speed, with 1st gear "granny" low. Three speeds were column shift, never seen one on a 4WD but that don't mean they don't exist.
Looks like the entire passenger side and part of the driver's side front of the truck has been repaired, probably bondo-ed. Use a magnet to see if it's metal or bondo.
Now, whatever rust you see on the driver's side was probably the same as what is hidden on the passenger side.
So, if it's bondo (I'd bet on it), it would be considerably harder to fix that side correctly than it would be to fix the very rusted driver's side.
Also, keep in mind that rust is ALWAYS worse than it looks. Read some build threads and you will understand this. Once you start sanding/stripping you find a lot of ugly hiding under a precarious layer of paint or bondo.
It appears to have a metal bed, so you MUST remove that bed-liner that does not fit and inspect the bed floor. A good bed floor is a very usable/sellable salvage part. You might get lucky on that one, if it had a camper on it for most of it's life.
Check the frame rails in the area of the gap between the cab and the bed.
Looks like the entire body is shot beyond reasonable repair.
If you can get this thing running, and it's solid frame and mechanical, I'd advise getting another entire truck for a donor body. But again, body must match title. Don't know the laws in your state, don't know if you can mix/match body/frame, don't know if you could get a new title if you had title to the existing frame and title to a replacement body (cab).
Make sure you can do whatever you want to do, legally.
Old 11-18-2014, 04:28 PM   #16
MARKDTN
Originally Posted by mechanicalman View Post
...According to my research, 327 engines were still manufactured in 69 but I don't think they were offered in trucks that year being replaced by 350's. I am 100% sure you could get them in Impala's and Camaro's...
That is partially right. 327 was introduced in 1962 as a small journal like all 283s. In 1968 the large journal 327 was introduced. The last year for a 327 in a pickup was 1968. The last year for a 327 in a Camaro or Corvette was 1968. The Impala did seem to carry over to 1969 at least part year. I can find no application for a 327 in the bigger than C30 trucks past 1968 either. So really 1968 was the last year with any volume.
The '68 up large journal 327 block is a 4" bore and is the same as a 350 block. The 327 was never offered as a 4 bolt main engine even in Corvette or Camaro, but you can build one with a 4-bolt 350 block. The 307 basically replaced the 327 (although 68 B-bodies were available with both 307 and 327). The 307 and 327 share crankshaft stroke. There is a forged large journal 327 crank available in the higher horse motors.
Hope that helps clarify.
OP-to really know I you have a 350 or 327 you would have to measure the stroke. I think you have bigger issues to decide than which engine is in there. Either one is fine for a driver.
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 11-18-2014, 04:50 PM   #17
SS Tim
SS Tim's Avatar
With the t case lever on the left I'd say it was a 69 with a Rockwell T-211 t case. That being the case it probably still has the drum brake front.
The fact that it was used as a plow (note the joystick) would be a very heavy detractor even on a nice truck. Being 17 I see this as a money pit full of hard to find parts needing a lot of work. Like most I'm sure you want a nice truck for minimal investment and I don't see it here. Being in a salvage yard I would also suggest looking well into the title, engine numbers, bodytag (rivets) and the frame first.
Links you will probably need.
* VIN/Model Decoders
* Power Team Charts (engine/transmission/gear ratio)
* Post Your Pickup SPID Blazer SPID Suburban/Panel SPID
* RTFM
... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 11-18-2014, 05:46 PM   #18
Cam-Shaft
Thanks again guys, going to look very carefully at it this Thursday. I will take everything into account that you mentioned and will keep you posted. I know all about money pits, I had a "500" dollar front end loader project that ended up at 3500$
Will keep you posted!
Old 11-18-2014, 05:58 PM   #19
mechanicalman
Clarify what? So, if it's "partially right", what part of it is wrong? Be specific.
Old 11-18-2014, 06:07 PM   #20
dmack91
dmack91's Avatar
A good rule of thumb on projects is be realistic in you estimates of time and money. Then, multiply the $$ estimate by 3 and the time estimate by 4, and you will generally be in the ballpark.
68 Chev C20- son has it now
83 K20 - bought from son
70 C20 - in progress
dmack91 is offline   Reply With Quote
Old 11-18-2014, 06:29 PM   #21
67ChevyRedneck
67ChevyRedneck's Avatar
If I see what I think I see... the area above the windshield and the drip rails are completely shot. Not uncommon for your neck of the woods. It looks to me like she's only worth a few hundred bucks... and that's if it runs.
I would buy the truck as a fun 4x4 to learn on. I wouldn't get big dreams of a restored truck for this one.
As a former rust belt teenager, I'll be the first to tell you that chicken wire/wire mesh, or any crap shoved behind rust covered in bondo will look like crap within 6 months and is a complete waste of time. If you do plan on rust repair, do it right, or don't bother. However, if there are holes in the cab, do seal those up however you can, you don't want to be sucking in exhaust fumes.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-18-2014, 07:09 PM   #22
thepenguin99
If the motor runs and the truck isn't very expensive go for it. As others mentioned I wouldn't plan on restoring it. More like find a drivers door/front bumper, seal the cab holes with some fiberglass, whatever mechanical work is necessary, paint it flat black, and run it. On the positive, those wheels are fairly sought after, $300ish right there.
thepenguin99 is offline   Reply With Quote
Old 11-18-2014, 09:21 PM   #23
Cam-Shaft
If I look at it and it looks right, the agreed price is 800$. He said the frame is solid and the engine/tranny are good, am I wrong in thinking I could part it out and get my money back?
On a side note, how can I tell if the drip rail is shot? Is it simply looking for rot or holes?
Still getting excited! I love the idea of a classic truck with a 4 speed. Even If I don't restore it, I hope to make it mechanically sound so I can drive it around some.
Old 11-18-2014, 09:33 PM   #24
71swb4x4
71swb4x4's Avatar
You will get $800 parting it. Those look like 15x8 steel wheels which are pretty popular right now, they sell for $300+ for a set of 4.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 11-18-2014, 09:37 PM   #25
thepenguin99
You can see the drip rail is shot by the interior pic you posted. Look between the drivers visor and windshield. Pretty sure I see daylight. Hard to tell but looks like the firewall is eaten out above the distributor. Probably also eaten out around the heater box.
As far as parting it for $800. Shouldn't be a problem if you don't value your labor highly. If the wheels are 6 lug 15x8 (looks like they are) and the motor runs good those two items + scrap = your money back and a little extra.
