Old 11-18-2014, 05:51 PM   #1
thefixer51
z-clutch arm
my 69 c-20. just dropped a new 350 crate motor in it. I bought the truck with no motor. 4 speed manual trans.I can't seem to get the nut tight on the end off the clutch z-arm. The bolt inside spins with the nut. Any tips on how to tighten this nut.
Dave
thefixer51 is offline   Reply With Quote
Old 11-18-2014, 08:18 PM   #2
JimKshortstep4x4
Re: z-clutch arm
Welcome to the 67-72 Chevy Truck Forum from West Michigan!
There should be two flats on the stud which fit into the slots on the frame member. Check the slot on the frame mount to see if it is worn. A quick fix if it is worn is to weld up the wear area and grind the slot to size. Sometimes the flats on the stud wear but usually it is the frame mount slot.
Otherwise if the member is worn, replacement is an option.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-18-2014, 09:24 PM   #3
thefixer51
Re: z-clutch arm
I knew it was something simple. It's in a really tight spot. Thanks for your help
Dave
Old 11-18-2014, 10:57 PM   #4
Lattimer
Lattimer's Avatar
Re: z-clutch arm
I had to jam a screwdriver into the side of mine to get the nut off, then I welded up the bracket so it fits right. Its a pain in the butt spot to get too unless you pull the fender and wheel well.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
