Old 11-25-2014, 09:59 AM   #1
domano 68
Talking Newbie 72 Cheyenne
New to the board and C10s. Picking up a 72 Cheyenne this weekend. Seems to be in pretty good shape. Its been sitting for about 5 years.
I'd like to change out the fluids. What weight oil is recommended for these older vehicles? Dino or synthetic? Would a zinc additive be necessary?
I'd like to flush the brake fluid so I need to know what is recommended there also, DOT3, etc. Is this a pretty easy procedure?
Thanks in advance!
domano 68 is offline   Reply With Quote
Old 11-25-2014, 06:38 PM   #2
engineer_gregh
engineer_gregh's Avatar
Re: Newbie 72 Cheyenne
Hi and welcome to the board. I would turn the engine over by hand to make sure nothing has seized if it hasn't been started in 5 years. I would also recommend draining the gas tank and blowing out the fuel lines before I attempted to start the engine. Then I would use regular motor oil, 10-30 or 10-40, with ZDDP additive. I'm pretty sure regular DOT 3 brake fluid is correct. Good luck and keep us posted, everyone here likes pictures!
1971 Longbed BB Cheyenne Super
1972 Longbed SB Cheyenne Super
1972 Longbed Highlander Custom Deluxe
1975 K5 4x4 full convertible
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=645165
Greg Smyrna TN
engineer_gregh is offline   Reply With Quote
Old 11-25-2014, 08:42 PM   #3
70cst
70cst's Avatar
Hey domano 68
to the forums and from Ohio
on your new ride
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-25-2014, 09:33 PM   #4
SS Tim
SS Tim's Avatar
Start with a factory service manual, here are downloads until you can buy an easier to use paper copy. An owners handbook is also a very good thing to have starting out and most every truck parts seller has reprints.
I'd stick to dino starting out and if you are new a mentor is worth seeking out. Don't forget to post a picture (or more) of your "new" truck!
* VIN/Model Decoders
* Power Team Charts (engine/transmission/gear ratio)
* Post Your Pickup SPID Blazer SPID Suburban/Panel SPID
* RTFM
... Read The Factory Manuals... download 'em here
SS Tim is offline   Reply With Quote
Old 11-25-2014, 10:07 PM   #5
domano 68
Great information everyone. Thanks much for chiming in and sharing the[links to the manuals! I'll get pics up in a few days.
Old 11-26-2014, 09:03 AM   #6
brown7373
brown7373's Avatar
I would drain the oil and change the filter and use 10W30. I don't think the additive is that important with an already broken-in cam running stock springs. New cam break-in, especially with heavier springs is a different story. But it's not that expensive if it makes you feel better. I would change the oil and filter a second time, after it runs for a while, because you will drain cold oil that all the junk has settled out and been sitting for 5 years. After the initial start, the new oil will be hot and the junk that was on the bottom of the pan will then be drained out with the 2nd oil change.
Also drain flush and replace the radiator coolant. You need to check and replace the hoses which may be weak. Same with brake hoses, which often deteriorate from the inside out. I would doubt that a truck that sat for 5 years has recent brake hose replacements.
After you get it running, you can check and replace brake components as needed
brown7373 is offline   Reply With Quote
