Old 11-08-2014, 01:11 PM   #1
joewell80
LS T56 Swap
I am thinking about installing a LS T56 in my 70 C10 with a SB 350.
As I am doing more research, it seems like there is lot of extra parts I will need. QuickTime has a bell housing but its pretty expensive, does any body know of any other bell housing available?
Thanks.
joewell80 is offline   Reply With Quote
Old 11-10-2014, 09:20 AM   #2
Zeke's Garage
Zeke's Garage's Avatar
Re: LS T56 Swap
I'm putting an LT1 T56 in my Chevelle wagon right now, and am finding that it's requiring significant work on the floor boards and driveshaft tunnel. A high hump tunnel might be enough in the trucks, but you may find you need more work within the cab.
As for additional parts, you're going to need to verify the clutch, bell housing adapter and hydraulic release bearing setup you want to use. I'm cobbling together original parts such as all the pedals and linkage, with newer clutch master cylinder and reservoir.
I found that the yoke from my old power glide works fine in the tailshaft of the T56, but the drive shaft will have to be cut. Not sure of the output splines of the newer T56, but it's another part to factor in. Also, you'll need to figure out how you're going to deal with the electronic speedo output. I'm probably going to run some aftermarket gauges and just go electronic in the Chevelle.
It won't be cheap or easy, but what is on these things?
Good luck!
'67 Chevy Stepside
250 Inline 6
Megasquirt Fuel Injection
T5 5 speed conversion
Ferric Oxide impregnation throughout
Zeke's Garage is offline   Reply With Quote
Old 11-10-2014, 12:35 PM   #3
Fitz
Re: LS T56 Swap
Thanks.
Hawks has a cast aluminum housing for the LS1/LS2. $250.00 and the adapter plate that you will need to marry it to your engine for $229.00. That's pretty much the cost of any of the steel housings like the Quicktime with more parts to fool with and a few headaches you probably don't need trying to find just the right other parts needed to make the combo work. Better to save the time and aggravation by opening your wallet a bit wider.
Fitz is offline   Reply With Quote
Old 11-11-2014, 04:28 PM   #4
joewell80
Re: LS T56 Swap
Thanks for the input.
1. Can I use the stock bellhousing from the T56, as long as I buy the spacer?
2. Will the factory clutch from the LS1 Camaro T56 work with the SB350?
Thanks,
Old 11-25-2014, 04:41 PM   #5
Nott32
Re: LS T56 Swap
I am wanting to do this swap from my th350 now. Research leads me different places and mostly old threads.
I have an LS1 t56
I read one place I can use the adapter then use the stock mech linkage, and bell/clutch/throwout from a muncie. No idea what flywheel to use or if I can use the starter I already have. But I can't find the link now
Anyone have some input? Im not afraid of going Hydraulic if I can but Im not dropping $600 on bell alone if I can help it. My budget is right around $500.
What I got so far
Adapter: http://www.thegearbox.org/catalog/it...17/4803441.htm
Pilot Bushing: http://www.thegearbox.org/catalog/it...17/6239106.htm
Clutch kit: http://www.summitracing.com/parts/zz...5-1a/overview/
I was looking at this flywheel...http://www.hurst-drivelines.com/?pro...2-pc-rear-seal
I was going to find a 70 with a manual and swipe the mech linkage and pedal....
thanks.
Nott32 is offline   Reply With Quote
t56 ls 350 c10 swap
