Old 11-27-2014, 04:08 AM   #1
yoshi
yoshi's Avatar
Fittings new fenders on 49
Gonna be fitting the new front fenders. I have some material to go between fender & body. I take it this go's near the door. This piece of material is straight but it has a raised edge on one side. Can anyone tell me which way round it should go before I punch the holes in it? Thanks
yoshi's 49 project
yoshi is offline   Reply With Quote
Old 11-27-2014, 07:58 AM   #2
Old Crow
Old Crow's Avatar
Re: Fittings new fenders on 49
The bead goes to the outside. Here's an article that tells how to do it:
http://www.classictruckshop.com/welting.php
Old Crow
'54 Chevy Panel, '00 Bounder 36S, '95 Jeep YJ
Old Crow is offline   Reply With Quote
Old 11-27-2014, 09:00 AM   #3
yoshi
yoshi's Avatar
That's great, many thanks
yoshi's 49 project
Old 11-27-2014, 05:42 PM   #4
yoshi
yoshi's Avatar
I take it the outer fender sits on top of the inner fender. I bolt through the outer into the inner. Do the hood latch panel sit on top or under the outer fender? I notice there is a hole about 2"x3" just under the hood hinge that has the round spring.
yoshi's 49 project
Old 11-28-2014, 04:08 AM   #5
yoshi
yoshi's Avatar
I've put the fender on but I can't get the holes to line up where the welting is. The fender needs to come down about 1/2-1"
yoshi's 49 project
Old 11-28-2014, 01:47 PM   #6
OrrieG
OrrieG's Avatar
Did you already fit the cab/hood/radiator support, those need to be fit first, then the fenders matched to the hood and cab. A factory assembly manual will show the sequence for installing all of the panels, I don't have an AD one.
Old 11-28-2014, 02:11 PM   #7
yoshi
yoshi's Avatar
Yeah all fitted except hood
yoshi's 49 project
Old 11-28-2014, 03:04 PM   #8
thunderjet
Yoshi: I will get flack from some of the members, but in 35 plus years of building hot rods, I can only think of one car that I put fender welting on. If the fenders will fit tight to the body, welting isnt required.
thunderjet is offline   Reply With Quote
Old 11-28-2014, 03:18 PM   #9
yoshi
yoshi's Avatar
Lol pity you didn't say earlier
yoshi's 49 project
Old 11-28-2014, 06:36 PM   #10
OrrieG
OrrieG's Avatar
You need to fit the hood to the cab and front core first, then fenders to the hood. Reason is just a little mis alignment of the cab angle and hood will throw everything off. Trying to save you the time and effort of hanging the fenders only to have to take them back off again. This sequence has been addressed a number of time here and on the stovebolt.com boards.
Old 11-28-2014, 07:10 PM   #11
Iceburgh
Iceburgh's Avatar
I agree...... I don like the look and if the gaps are prepared properly it is not needed
1953 suburban build
http://67-72chevytrucks.com/vboard/s...d.php?t=621331
Iceburgh is offline   Reply With Quote
