Old 11-27-2014, 06:20 PM   #1
Vinceg
Vinceg's Avatar
Replacing rust cab supports
Hey guys,
I'm new to this site. A guy I was getting parts off turned me onto the site. I've been snooping around and so far seen lots of cool stuff. I have a 66 chevy I pulled out of a farmers field this spring. My first truck many many years ago was a 66 also (good memories). I have always liked the style of the 60-66 chevy pickups. I have been plugging away at the truck and was wondering about the best way to replace the cab supports. Do I just keep drilling out the spot welds or should I cut out the floor? Is there a thread that shows this being done?
Vinceg is offline   Reply With Quote
Old 11-27-2014, 07:21 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: Replacing rust cab supports
If you skim through the many build threads here you can see pictures. Welcome aboard. Would like to see some pictures of the truck.
Old 11-27-2014, 07:44 PM   #3
Vinceg
Vinceg's Avatar
I'll try to get some pictures on here. I have lots on my phone. None in the tablet. I'll keep snooping around.
Old 11-27-2014, 08:11 PM   #4
mark 66
which ones are you going to replace? fronts aren't to bad but might be easier to section out only the bad sections on the rears. sounds like you have the right idea. keep drilling spot welds till it comes loose.
mark 66 is offline   Reply With Quote
Old 11-27-2014, 09:06 PM   #5
Vinceg
Vinceg's Avatar
Thanks, I have to replace both the front and rear. I have stitched in the inner rocker on the passenger side already and started wondering if I'd jumped the gun.
Old 11-28-2014, 10:36 AM   #6
ls60apache
hello as stated front ones aren't to bad. but the aftermarket rears are made for 67-72 and had to do some slicing and dicing to make them work. if I hadn't already bought mine I would have tried to fab my own. good luck!
ls60apache is offline   Reply With Quote
Old 11-28-2014, 10:46 AM   #7
Vinceg
Vinceg's Avatar
Thanks. I also have already bought new ones to replace the old ones. The old ones are pretty much gone.
