11-28-2014, 12:56 AM | #1 |
gauges
How do you check the gauges them self. 1967 c10. New sending unit for the temp. It still did not work. If I pull the cluster out how do I check each gauge? jim
11-28-2014, 04:44 AM | #2 |
Re: gauges
11-28-2014, 07:18 AM | #3 | |
Cluster King
Re: gauges
I can help you diagnose your temp gauge but I have some questions for you. First, what is wrong with the temp gauge? Is it pegged to full hot or does it not move at all? Does your fuel gauge work OK? Do you have a digital volt ohm meter (DVOM) There are many reasons why a temp gauge will not work correctly. Lets see if we can isolate your exact problem. Take care, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
11-28-2014, 09:51 AM | #4 |
Re: gauges
The gauge is all the way left. Fuel gauge works. Oil gauge works. Not sure about amp. I have a vom.
11-28-2014, 01:54 PM | #5 | |
Cluster King
Re: gauges
The fact that the fuel gauge works tells me you are getting battery voltage to the connector on the back of the cluster. The power for the fuel and temp gauge (pink wire) is shared until it splits off in the printed circuit board. The printed circuit board may have a burn spot in it but usually not a concern for your type of issue. Use your DVOM and check your voltage on the back of the gauge. With your ignition switch in the run position, it should have battery voltage. It will be the terminal that is near the passenger side. Looking at the photo I attached, the power side is the one with the red circle. Also you can check the ohms on the resistor. It should be around 55 ohms with the ignition in the off position or around 100 ohms if you remove it from the gauge. If you do not get any ohm reading from top to bottom of the resistor, then it is defective and needs to be replaced. First thing is to make sure you have battery voltage on the terminal with the red circle. I also have parts if you need any. Let me know what you find out, Take care, Tom
11-28-2014, 02:22 PM | #6 |
Msgt USAF Ret
Re: gauges
Try grounding the wire to the sending unit. If you're not getting power to the gauge it won't move (key on), if you have power to it, it should go to full hot. If it goes to full hot then the grounding wire is ok and the sending unit is bad.
In the link posted above the sending unit should read as follows. COOLANT TEMPERATURE GAUGE PARAMETERS For Truck Years: 1967 - 1973 The Temp Gauge Needle Should Point to: Left Line (Cold) when sender resistance = 350 Ω Middle Line when sender resistance = 76 Ω Right Line (Hot) when sender resistance = 51 Ω Test the ohms between the sending unit terminal and the engine block.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
11-28-2014, 02:33 PM | #7 | |
Cluster King
Re: gauges
Thank you VetteVet
11-28-2014, 05:53 PM | #8 |
Re: gauges
I ground the temp wire, gauge did not move. Sending unit is new. Have not had time to check the voltage on the gauge. Jim
11-28-2014, 06:13 PM | #9 |
Re: gauges
here is a pic hope it helps
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
11-28-2014, 09:11 PM | #10 |
Re: gauges
The bitterness of poor quality lingers long after the sweetness of a low price is forgotten. |
11-30-2014, 05:49 PM | #11 |
Re: gauges
When looking at the gauges the post next to the steering column has 9.4 volts on it. I will check the ohms later. Jim
11-30-2014, 08:42 PM | #12 |
Re: gauges
Good info for future use!
1971 Cheyenne SWB 402BB, 700R4, 3.73 posi, PS, PB, A/C, Tilt, Tach "Wanda" Don't argue with idiots, People watching may not be able to tell the difference... There's someone in my head........But it's not me...... cheap tricks thread great info here!! http://67-72chevytrucks.com/vboard/s...d.php?t=489394 |
11-30-2014, 09:46 PM | #13 |
Cluster King
Re: gauges
That voltage sounds a little on the low side but it does sound like your in the right spot. I would check this against your actual battery voltage at the battery. If everything checks and with what you have doe, my bet is the gauge is defective.
12-06-2014, 07:52 PM | #14 |
Re: gauges
The battery 14.3. I think I need to check my wiring & see where I am losing voltage. Jim
