11-29-2014, 11:23 AM | #1 |
Hazard Light Switch Stuck
I pushed in the hazard button/switch in, and now I can't pull it back out, and return it to normal, even though the hazards are not blinking.
Now when I step on the brake pedal both turn signal indicators light up on my dash simultaneously and the turn signal indicators no longer flash on the dash either when i try to use the turn signals, (not sure if the turn signals actually work themselves, probably need to check on that) 1974 GMC 1/2 ton pickup, 350 manual |
11-29-2014, 12:54 PM | #2 |
Re: Hazard Light Switch Stuck
well this is what the Service Manual suggests
CONDITION Hazard switch cannot be turned off: POSSIBLE CAUSE Foreign material between hazard support cancelling leg and yoke CORRECTION Remove foreign material 1. No foreign material impeding function of hazard switch — replace turn signal switch CONDITION Hazard switch will not stay on or difficult to turn off POSSIBLE CAUSE A. Loose switch mounting screws B. Interference with other components C. Foreign material D. None of the above CORRECTION A. Tighten mounting screws (25 in-lbs) B. Remove interference C. Remove foreign material D. Replace switch |
