Old 11-29-2014, 03:39 PM   #1
trb97
Leaf spring question.
I put 3 inch drop springs in today and it brought the front up 4 inches. Not surprised, the PO said he cut/heated the springs.
The PO flipped the back and did a clean c-notch. I'm not sue what else he did because it is really low.
Is there any way to bring the back up a couple inches without un flipping?
trb97 is offline   Reply With Quote
Old 11-29-2014, 03:44 PM   #2
trb97
Re: Leaf spring question.
This is now low the rear is.
Old 11-29-2014, 04:34 PM   #3
siggyfreud
siggyfreud's Avatar
Wow that must have been a rough ride with those front springs. They had zero compression in them it looks like.
siggyfreud is offline   Reply With Quote
Old 11-29-2014, 08:57 PM   #4
duallyjams
duallyjams's Avatar
Do you have any pics of the rear springs.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 11-30-2014, 03:40 PM   #5
63burban
Chevy addict
Omg !!!
63burban is offline   Reply With Quote
Old 11-30-2014, 04:16 PM   #6
trb97
Looks like the PO cut off then re-welded the perches on the other side of the axle.
Old 11-30-2014, 05:04 PM   #7
LVPhotos
LVPhotos's Avatar
Shackles. The axle position would move down and raise truck. OK I was looking at front perch. If axle shackles are hanging down and not sitting on top of rear perch, like front ones, this will work. If not you need to redo axle or flip rear perches.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 11-30-2014, 09:46 PM   #8
jtrichard
take the springs apart and reassemble them correctly (looks to be 3 or 4 short leafs above the main leaf they were under before) that will bring you up some other thing you can do would be take a sledge hammer to the springs one leaf at a time and put more arch in them you can put it just about any where you want then
jtrichard is offline   Reply With Quote
Old 11-30-2014, 10:54 PM   #9
trb97
Good info!! This is my first experience with leaf springs. I'll change them around tomorrow. Thank you.
Old 11-30-2014, 11:57 PM   #10
jtrichard
All the ones above the main leaf (the one with the eye ends) go underneath in the reverse order that they are in now.... you may need new center bolts (SPECIAL) places like Napa have them in like 2 different lengths... one more thing the way they are in now they are nothing more than a spacer when you put them back underneath your ride WILL be stiffer if you don't like the ride you could remove a few leafs like every other one or just remove all the leafs above the main and make a spacers (one size bigger nuts or short pieces of steel pipe under the nuts that are there now works great) to make up for what is missing so your "U" bolts will still work ...and your ride will be just as it is now... just so you know your hauling capacity is pretty low the way it is now..... hope this all makes sense
Old 12-01-2014, 01:35 PM   #11
boucher racing
boucher racing's Avatar
Originally Posted by trb97 View Post
Attachment 1331076
they did> here is a pic of a factory setup on the rear of my GMC
Build Threads: "JED" 66 GMC C1000
http://inliners.org/ubbthreads/ubbth...1857#Post61857
"Cropwell" 66 C10
http://67-72chevytrucks.com/vboard/s...d.php?t=587639
boucher racing is offline   Reply With Quote
Old 12-01-2014, 10:15 PM   #12
trb97
I switched them around and I gained like 3/4 of an inch. I'm going to make some shorter shackles for the back and drive it like that for a while.
Thanks for the help guys!
